TC33D Hydraulic leak around filter area
   / TC33D Hydraulic leak around filter area #1
kellym
2001 NH TC33D
I noticed a leak near my hydraulic filter. I replaced the filter because it was dented think that this was the problem. I still have a small leak. Is it possible to knock the body that the filter attaches to loose or could I have bent it. Any suggestions?
   / TC33D Hydraulic leak around filter area #2
Is this the filter that's up under/inside the right rear wheel? I've had mine get knocked right off the tractor a couple of times now (once by me when the tractor was less than a week old, and once by a friend who was borrowing it). Each time, the flange or adaptor that mounts the filter to the tractor got broken.
If your leak is around that filter, I'd take a good look at the filter mount and make sure it's not cracked. As I found out the hard way, it's not very well protected.
It wasn't that hard to replace the damaged parts myself ... you end up draining most of the hydraulic fluid out in the process. (make sure you get the gasket to go with the part)
John McNerney
   / TC33D Hydraulic leak around filter area #3
Use a straight edge to help determine if the mating surface is true.. if it ain't.. you can bet that it is damaged / warped / cracked.
Soundguy
   / TC33D Hydraulic leak around filter area #4
Strangely I noticed a leak, from the bracket holding the hydraulic filter(suction side) about the time you posted. A week and 20 hours on the tractor later, the dealer says it was just a cocked o ring. I am glad he fixed the leak,but did not anticipate 100 hour service to be due at the end of the week.
2011 Ford Transit Connect Cargo Van (A50323)
2011 Ford Transit...
2013 Hyundai Sonata Hybrid Sedan (A50324)
2013 Hyundai...
Genie GS-1930 (A50120)
Bad Boy 747cc Outlaw **Does Not Run** (A50121)
Bad Boy 747cc...
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
2007 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2007 Ford F-150...
