TC33D Grease Fitting Locations
   / TC33D Grease Fitting Locations #1
SteveInMD
Platinum Member
Brookeville, MD
TC33D
I'm not sure if I'm finding all the lubrication points on my tractor or not. I've got one lube point list under my hood, one on page 3-2, 3-3, and 3-4 of my operator manual. Each of these four lists are similar and contain some of the same points, but they are not the same. I really wish there was a single complete list with a numbered diagram. Does anyone have such a list? If not, can someone tell me where the 2-Wheel Drive King Pins fittings are? How about the Steering Linkage? Does the 3-Point Linkage refer to the turn-buckle with the hand crank? I think the NH documentation is really poor on this issue.
   / TC33D Grease Fitting Locations #2
Steve,
The King Pin is the vertical shaft attached to the front axle and has a steering arm attached to the top. It rotates when the wheels are turned left and right. The grease fitting should be straight up on top by the steering arm.
As for the 3-point, I grease the hand crank adjuster on the right side and then all the attachment point swivel ballls.
I only have the same list you have and was thinking of making up a "walk-around" checklist to get all the lube points. I'll post it when it's done, unfortunately it's about 900 on my list of the top 1000 things to do. /forums/images/graemlins/blush.gif
   / TC33D Grease Fitting Locations #3
It sure would be nice if there was a one page document that listed all of the zirks. then you would not miss any of them. My book does show some of them but I really don't think they are all listed.
murph
   / TC33D Grease Fitting Locations #4
As Steve mentioned, Page 3-3 of the Operator's Manual has a diagram with a description of all the tractor lubrication points. /forums/images/graemlins/smile.gif
MikePA - That's the problem, the list on 3-3 is not complete. There are more listed on 3-2, and 3-4, and under the hood, but not shown on a diagram.
   / TC33D Grease Fitting Locations #6
</font><font color="blue" class="small">( As Steve mentioned, Page 3-3 of the Operator's Manual has a diagram with a description of all the tractor lubrication points. /forums/images/graemlins/smile.gif )</font>
As Steve mentioned, there is some on other pages also. And even the ones that are on the other pages still does not make a complete list of what is on my tractor. I believe reading Steve's post he was looking for a one page document that listed ALL grease zirks. /forums/images/graemlins/confused.gif
murph
   / TC33D Grease Fitting Locations #7
Of the fittings listed on 3-2 and 3-4, the following are not on the diagram on 3-3
3-point linkage (the crank mechanism on the right side) - 1 fitting
Upper 3ph Link - 1 fitting
Clutch, HST and Brake Pedal shafts - 1 fitting each
Add these to the list on 3-3 and it's a complete list
There's no reference to 2-Wheel Drive King Pins in my manual.
The list from under my hood reads:
Steering Linkage
3-Point Linkage
Pivot Shaft
Brake Pedal
Drive Shaft Cover
HST Foot Pedal
Power Steering
Also, if you don't happen to have SuperSteer there are a bunch of extra ones on 3-3.
I probably dont miss any, but a single list and diagram should have been provided by NH.
   / TC33D Grease Fitting Locations #9
<font color="blue"> a single list and diagram should have been provided by NH. </font>
I agree.
BTW, I spent an hour one afternoon with the manual and a flashlight locating all the grease fittings, then I put bright green grease caps on every fitting.
The list under your hood matches the list on page 3-2, except for the 2-Wheel Drive King Pins. I don't believe 4wd drive tractors have these.
I like the idea of the bright colored caps. I'll try to find some.
2017 GENIE GS-2646 (A52472)
2017 GENIE GS-2646...
2018 Sakai SW990-1 Tandem Vib Roller (A52384)
2018 Sakai SW990-1...
2018 Freightliner Day Cab, Detroit Diesel, Auto (A52384)
2018 Freightliner...
(1) 12ft Tarter Gate (A51573)
(1) 12ft Tarter...
