TC33D Fuses and dreaded no start/switch issue
   / TC33D Fuses and dreaded no start/switch issue #1
Dakotasc
Columbia, SC
New Holland TC33
I purchased a used 2004 TC33D and it had the same switch issue as described in the sticky thread. The flasher module had to be replaced and I used repair manual for guidance. I also checked fuses and discovered mine were not arranged as shown in manual (see pics). There is a 30amp fuse in what should be an open slot (see pics). When I removed this fuse - nothing...no starter engagement no turn over. When I put back in then it was the usual click click click - switch key back and forth then it cranks. I'm wondering if that 30amp fuse was the previous owners attempt to fix the switch? Any suggestions? THANKS
2011 Chevrolet Impala Sedan (A55853)
2011 Chevrolet...
Push Mower (A55973)
Push Mower (A55973)
40' High Cube Multi-Door Container (A53314)
40' High Cube...
2009 International 7400 T/A VacCon V311LHA Combination Sewer Jetter Vacuum Truck (A56858)
2009 International...
2012 Honda Civic Sedan (A55853)
2012 Honda Civic...
ALLMAND NIGHT-LIGHT PRO 4 BULB LIGHT PLANT (A52706)
ALLMAND...
