TC33D Dashboard
   / TC33D Dashboard #1
Florida_Farmer
Central Florida
841 Powermaster, TC33D, TC40 DA, Yanmar 1500, Yanmar 2210B, Scag Turf Tiger, Exmark 72" Lazer Z
Took off my dash to change out the flasher module but the retainer nuts that were in the fiberglass cracked off on both sides - I guess it's age or something.. any idea how to repair it or find a auto clip that might hold it in tighter?
It sits ok without falling out but I need to fix it but would prefer not to buy a new dash cowling...
Thanks
   / TC33D Dashboard #2
To change the flasher module, I thought all you had to do was take off the panels underneath the dash, not the dash itself? :confused:
   / TC33D Dashboard
Started there but 2 screws on the dash looked much easier - and did provide easy access to the module - only problem was the brittleness of the fiberglass. Otherwise, would have been 3 minutes and done...!
   / TC33D Dashboard #4
Not sure what the problem looks like but I've had good results making repairs with Super Glue or epoxy glue. As long as there is a good surface to work with.
You can also find a hefty selection of automotive clips at any good parts store.
   / TC33D Dashboard #5
Mine has cracks showing around holes also; not sure but is it possible to drill new hole, countersink them and and hold it in a different location? Glue will probably just crack again.
   / TC33D Dashboard
Thanks - not much left to work with - I'll take a picture but I think I'm going to use a little PVC glue and stick a small tab on to screw to.
I'll let you know how it turns out..!
   / TC33D Dashboard #7
I guess you could use a washer on a flathead screw so it grabs some good material.
   / TC33D Dashboard #8
A plastic welder would be best. I think Harbor Freight carries an inexpensive one. I know that they carry the plastic welding rod.
JB Weld another option.
   / TC33D Dashboard
Thanks - good suggestions - I'll look into the plastic welder - sounds interesting
JOHN BLUE 1000 GALLON ALUMINUM NURSE TANK (A52708)
JOHN BLUE 1000...
2014 Takeuchi TB290 Mini Excavator, S/N 1851007797, Diesel Engine, Tag 24" Bucket w/Thumb, 18" Wide (A59076)
2014 Takeuchi...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
4" X 4" WATER PUMP W/ HONDA ENG (A52708)
4" X 4" WATER PUMP...
1995 Koehring LRT-110 7.5 Ton 4WD Rough Terrain Crane Truck (A55787)
1995 Koehring...
