TC33D cooler to HST filter line noise.. why?
   / TC33D cooler to HST filter line noise.. why? #1
paine
SE Michigan
Case DX33 Farmall
I have a Case DX33 FARMALL (TC33DA in red paint) and I have noticed some chattering type noise from the line that connects the HST filter housing to the cooler. I have checked the hose flames that would typically cause air leaks in the system, I changed the HST filter but I am not sure where the suction screen is so I didn't clean that. The fluid is at the correct level from what I can tell, I have been checking it with the FEL on the ground.
I have not yet tried a hydro fluid/filter change as I plan on picking up some AMSOIL but just have not wanted to spend the money on it yet. I did want to get the synthetic AMSOIL in there before winter and I guess this will just be a reason to get it in there now. I would like to rule out other possible problems as I don't want to get the new expensive hydro fluid in there and have to drop the filters again or remove any lines to wast fluid. Ill pose a pic of the line I am referring to in a few.
its the longer line in the front view pic and the lower line in the side/filter view pic. My pup was just trying hide from the rain that we were getting when I took the pics.
Thanks for any ideas!
LOT: (7) Wheel Loader Shanks (A59076)
LOT: (7) Wheel...
2008 Featherlite Portable Office Command Center T/A Trailer with Wacker Neuson G50 Towable Genera... (A56858)
2008 Featherlite...
10,000 PSI AIR HYDRAULIC PUMP (A58214)
10,000 PSI AIR...
MASSEY FERGUSON 275 TRACTOR (A58375)
MASSEY FERGUSON...
Carry-On 6'x8' Trailer (A53316)
Carry-On 6'x8'...
2015 GMC 3500 HD 4x4 Crew Cab Pickup Truck (A55973)
2015 GMC 3500 HD...
