Tc33
   / Tc33 #1
Hartrenic
Irasburg vt
Tc 33d
Tractor won't start. The first of three big square fuses(?) on the rt side of tractor is humming when the key is on. Don't know what the fuse is for. I called around and was told that was odd. Any clues?
   / Tc33 #2
I looked at the manual, the "square fuses" are probably your safety relays, good place to start troubleshooting.
   / Tc33
Thank you but my problem was a grounding issue. Even though all my grounds seemed tight and clean it was still my problem. Undid every ground and used some sand paper. Started right up.
   / Tc33 #5
Excellent news! Glad you are running.
I cleaned all my grounds but it didn't fix my starter solenoid intermittent, guess I'll have to replace.
   / Tc33
Ya I was thinking starter issues also but my problem was the ground on the lower right side of engine block. It was tight and looked clean but I still took it off and sanded both the block and wire connection.
2018 Ford F-150 Ext. Cab Pickup Truck (A51692)
2018 Ford F-150...
Diesel Forklift (A51691)
Diesel Forklift...
2013 HINO CONV. ICE CREAM TRUCK (A52472)
2013 HINO CONV...
2012 International 4300 Reefer Truck (A52748)
2012 International...
1996 HEIL TRAILER INTERNATIONAL FUEL TRANSPORT TRAILER (A52472)
1996 HEIL TRAILER...
