TC33 started running rough and dying.....
   / TC33 started running rough and dying..... #11
Soundguy said:
I like the easy bleeding system on my NH.. just turn key on and then unscrew a plastic plug on the fitler assembly tillair escapes and fuel bubbles... drain 2 water traps.. then crank up.
Still.. even having to crack lines athe injectors on the other diesels I've had wasn't too bad... It made you really think about NOT running out of fuel, and NOT putting bad fuel in!!
Soundguy
Soundguy, might I ask you on my TN70A for help? I have done nothing with the fuel filter since I have been afraid of not being able to start it and then have done more harm then good. Can I change my fuel filter and not have to crack (bleed) the injectors? HELP!
Bob
   / TC33 started running rough and dying..... #12
Doc_Bob said:
Can I change my fuel filter and not have to crack (bleed) the injectors? HELP! Bob
My experience (not on a TN70) is that if you fill the bowl to almost overflowing with fuel you can sometimes avoid bleeding the injectors.
   / TC33 started running rough and dying..... #13
Bob
I don't have a tn70, but rather a 7610s. On min, I have the fuel tank and tap ( with filter intank above tap ), then a water trap, (with bleeder ), then an electric pump with a canister filter with integral water trap, then the injector pump.
On mine, you unscrew the canister filter locking ring, remove/repalce the filter and lock in place, open the water trap on the bottom, and then open a bleeder knob on the filter assembly.. on mine it is a plastic 'finger' knob..then turn the key to the run position .. the pump will come on.. fuel will bubble from the knob, then close it.. then fuel will run fromthe bottom of the filter, close it.. then open the fuel cap.. you may see bypassed fuel run back into the fuel tank.
If I have a source of clean diesel, and a clean filter/funnel.. I sometimes fill the filter before instalation... however out in the field.. clean filter and filter funnel aren't available.. so i let the pump prime it.
After that I go back and drain the first water trap, again.. with fuel pump still running... then I go to crank her. Typically it takes about 1 - 1.5 seconds to crank her.. after a fuel filter change, that goes from 1.5-2.5 seconds.. usually 2...etc.
I'm not sure how that applies to your tn 70.. except that I've seen alot of the same fitler assemblies, fuel taps and pumps on many large NH tractors.. same with the deluxe hyd spools and qd's.
Good luck!
Soundguy
207276 (A52708)
207276 (A52708)
2025 GPS Trailers (A56857)
2025 GPS Trailers...
Jet Ski (A59231)
Jet Ski (A59231)
1995 NEWTON CROUCH PULL SPREADER (A57192)
1995 NEWTON CROUCH...
Rainbow Self-Propelled Volume Gun (A53317)
Rainbow...
2022 NEW HOLLAND 266BMM 66-INCH BELLY MOUNT FINISHING MOWER WITH SIDE DISCHARGE (A57024)
2022 NEW HOLLAND...
