TC33 hydrolic service
   / TC33 hydrolic service #1
schmism
Super Member
Peoria IL
New holland TC(33)
Well at only 253 hrs i went ahead and changed all the oil in the tractor (300hr service)
so a few notes on my experience
1) the dealer thinks filters have platnum filter eliments or something
$60 for all 3 oil filters. :eek:
2) got 10 gals of "generic" trans fluid at the rural king for $30 a 5 gallon
3) if your new to the oil service game on a tractor. save your self some headach and get yourself a strap wrench if you dont already have one. NOTE if ou dont have one, you CAN get a rachet strap looped around the filter 3 or 4 times, then have a helper pull on the end while you twist by hand... the combined force will losen a otherwise impossible to move by hand filter.
the small gold mine
note the old filters still seem to have the factory paint on them!?!?! IS this normal? the engine oil fiter is a denso filter. Is that what they put on them at the factory or has it been changed? It also was not comforting to know that the rear drain plug had not been disturbed. still had the factory paint on all surfaces.
mmmmmmm LOTS of old oil. Hows that look? :cool: Oh and 7.5 gallons seems to be about right. And i couldnt find a quanty on the engine oil. Seems like it took 4qts to fill on the dipstick.
btw does anyone know what the amount difference is on the trans oil dipstick (like a gallon from low to high?)
oh and the label from the generic oil. What i can tell you is that hyd pump went from whinging virtually ALLLLL the time to nice and quiet. The FEL seemed to be more responsive also.
http://www.snjschmidt.com/pics/property/trans_fluid.jpg
(thats a full size img 56k warning)
   / TC33 hydrolic service #3
Doc_Bob said:
Okay, what is that brown fluid?
Bob
I was wondering the same thing, It is either Liquid Carmel , or Water in the Hydro Fluid/ Oil :( :( :( :( :eek: :eek:
ill have you know (what came to my mind) was liquid peantbutter thankyouverymuch :cool:
anyone want to speculate on weather the 50hr service was ever performed?
(i aquired it at 212hrs give or take a few)
   / TC33 hydrolic service #5
Whatever fluid it is, it sure don't look healthy. Chocolate milk shakes are never a good sign.
   / TC33 hydrolic service #6
I will vote no.
Bob
   / TC33 hydrolic service #7
TC-33 calls for NH134 fluid ; is what you used tthe same. I did not see NH 134 listed.
Also, after seeing the oil; better change the coolant also; doubt if it was ever changed. I would also change engine oil within next 50 hoours, since it may have been over do for a change. This would be insurance for sludge build up. Someone here may know of an additive to add to hyd. oil as it has been contaminated with something (water). May want to change it out shortly to get rid of all contamination.
   / TC33 hydrolic service #8
Make sure your hydro oil is NH134 fluid.
Bob
   / TC33 hydrolic service #9
Sometimes camera flash units can cause things to look funny, but that oil sure looks contaminated with water to me. I'd look for condensation or change the oil again at a short interval as previously suggested. My transmission oil at 300 hours is clear with just a tiny tint of contamination. Your oil looks really full of water and that could mean the water has caused some amount of rust inside your casings; thus, the brown oil.
I'm not surprised your transmission sounded so bad on that stuff. Your tractor's innards are sure to be better served by the new oil. I used a quality generic oil the last time I changed my fluid and the next time I'll go back to NH fluid. I think the generic oil seemed to have a higher viscosity than NH134.
At the hours you have on your tractor, your oil should not look that bad. You have internal condensation or something else going on that caused that. I'd keep an eye on it. It could have happened somewhere between Japan and your dealer in MO, or who knows since you bought your tractor used. Now that it's yours and you are using "platinum" products, this kind of problem should disappear. I hope you don't have any other problems because of this.
   / TC33 hydrolic service #10
Yes, I think so, because the filters you took out don't look like NH filters to me. I am not sure, how that hydraulic oil got that much water in it, but lemme tell you that I never changed my hydraulic oil yet (only filter) and have 200hrs on the meter. Mine still looks good, no cloudyness at all. That hydraulic oil you took out sure does not look good, probably some rust and goo contaminated the filter and that why the pump was whining due to the restriction and loss of the lubericity of the oil. In your case I would look at that oil more often and change it again. Remember that there is still 2 or 3 gals of that contaminated stuff in there. It's quite thinned out now, but you'll see on the dipstic and veryfy the oils colour with new stuff.
2014 Kia Sedona Van (A50324)
2014 Kia Sedona...
2020 Nissan Rogue SUV (A51694)
2020 Nissan Rogue...
2008 New Holland B110 MFWD Loader Backhoe (A52748)
2008 New Holland...
New Wolverine Skid Steer Hydraulic Breaker (A53002)
New Wolverine Skid...
2015 Toro Z Master Professional 64in Zero Turn Commercial Mower (A50322)
2015 Toro Z Master...
