schmism
Super Member
Well at only 253 hrs i went ahead and changed all the oil in the tractor (300hr service)
so a few notes on my experience
1) the dealer thinks filters have platnum filter eliments or something
$60 for all 3 oil filters.
2) got 10 gals of "generic" trans fluid at the rural king for $30 a 5 gallon
3) if your new to the oil service game on a tractor. save your self some headach and get yourself a strap wrench if you dont already have one. NOTE if ou dont have one, you CAN get a rachet strap looped around the filter 3 or 4 times, then have a helper pull on the end while you twist by hand... the combined force will losen a otherwise impossible to move by hand filter.
the small gold mine
note the old filters still seem to have the factory paint on them!?!?! IS this normal? the engine oil fiter is a denso filter. Is that what they put on them at the factory or has it been changed? It also was not comforting to know that the rear drain plug had not been disturbed. still had the factory paint on all surfaces.
mmmmmmm LOTS of old oil. Hows that look?
Oh and 7.5 gallons seems to be about right. And i couldnt find a quanty on the engine oil. Seems like it took 4qts to fill on the dipstick.
btw does anyone know what the amount difference is on the trans oil dipstick (like a gallon from low to high?)
oh and the label from the generic oil. What i can tell you is that hyd pump went from whinging virtually ALLLLL the time to nice and quiet. The FEL seemed to be more responsive also.
http://www.snjschmidt.com/pics/property/trans_fluid.jpg
(thats a full size img 56k warning)
the small gold mine
