TC33 and TC34 differences
   / TC33 and TC34 differences #11
My loader is an LX114. Specs with a 68", 265 lb bucket, from the manual -- Lift capacity at maximum height - Pin, 1461 lb. 500 mm forward, 835 lb.
Lift capacity to 1.5 m - Pin, 1861 lb 500 mm forward, 1113 lb.
Breakout force at pin - 3071 lb. 500 mm forward, 1906 lb.
If your information is correct, I'm pretty happy I got the Case rather than the NH back in spring. I'm pretty sure the only differences were in the paint and the lights, not the loaders.
I have a 60" QA bucket, which I presume is a bit lighter than the 68" heavy duty material bucket specs are for.
   / TC33 and TC34 differences #12
The new Holland and Case loaders for the class II Cuts changed at the same time (I just don't happen to remember exactly when that time was), so that would not have been a factor in choosing one over the other.
John Mc
Tubing A500 Grade C 6in. SQ X 1/4in. X 28ft. (A50860)
Tubing A500 Grade...
71057 (A49346)
71057 (A49346)
2007 Dodge Durango 4X4 SUV (A48082)
2007 Dodge Durango...
CHALLENGER VACUUM PUMPS (3) (A50854)
CHALLENGER VACUUM...
UNUSED 2-Pack Blue Ratchet Strap Set (A50860)
UNUSED 2-Pack Blue...
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A51039)
Neckover GL24-2-7K...
