TC30...what size R4's
   / TC30...what size R4's #1
skargo
Hazzard County Maryland
NH TC30
I want to get some R4's, what size would I need for my TC30, and who has them for the best price?
Thanks.
I'm guessing I just use the size on the turf's sidewalls for ordering my R4's?
   / TC30...what size R4's #3
Just going out on a limb here, but I bet you will have to buy new wheels.
I found a brochure online that list the turf tires on a TC30 at 13.6 x16 and for R4s as 15 x19.5 for the rear. On the Front turfs are 24x8.50-14 and R4s as 25x8.50-14. You might be able to find an R4 to fit your wheel, but I doubt it. Though it does look you won't have to buy front wheels.
   / TC30...what size R4's #4
Isn't there a consideration of matching the front and rear's if you have 4-wheel drive? I think I've heard you have to buy new wheels also. I'm sure someone with more knowledge will confirm.
Funny thing is I went home for lunch, and my new operator's manual had the sizes listed. Can't remember if I would need new wheels too?
After getting it stuck with the turfs, I decided i would get the R4's and be done with it. I'll have the rears loaded too.
   / TC30...what size R4's #6
If you are wanting ultimate traction, R1 - Ags would be the way to go. I have the R4s on my machine, while they do OK, they will fill with mud and can become slick pretty quick. For what I do though, I think they are the best tire.
I have 2 smaller areas that are mostly swampy, the rest is fairly level, with a few ditches, with a long, mostly gravel drive. I do have a decent sized asphalt pad and portion of the driveway.
I can stay out of the swampy areas, do you think the R1 or the R4 tire would be better for my intended use?
   / TC30...what size R4's #8
While it is dry, I really like my R4s. In the mud though they become slick prety quick. Usually 4wd and a fair amount of spinning and I'm through. When I bush hog our ditch/creek area I do get stuck fairly often. Usually I'm backing in so the loader doesn't to a great job of pulling me out - usually end up and get the truck. I've only been so stuck once that the truck couldn't pull me out. I went to get the neighbor with his 36 HP Long w/ ags. He spun a fair amount pulling me out. Of course, I've had to pull him out of the same ditch a time or 2 myself.:D
The R4s won't mess the yard up as bad as an ag, but don't grip as well either. They aren't great at anything (except loader & pavement work) but have better traction (usually) than turfs but don't mess stuff up as bad as ags - unless you start spinning. They will then mess it up pretty quick w/ probably more damage than the ags because the ags probably wouldn't have spun. I would probably get the R4s for your use - but that is just me.
BTW, R4s usually have a thicker sidewall which help in loader work by not bulging and also in puncture resistance.
2007 POWERSCREEN CHIEFTAIN 2100X INCLINED SCREEN (A53426)
2007 POWERSCREEN...
2019 POLARIS RANGER XP PROSTAR 900 HD DOHC UTV (A51406)
2019 POLARIS...
2021 JOHN DEERE 60G EXCAVATOR (A51246)
2021 JOHN DEERE...
(2) 330 GALLON POLY TOTE (A51248)
(2) 330 GALLON...
2025 SDLANCH IRGC40 UNUSED Electric Tricycle (A53117)
2025 SDLANCH...
