TC30 vs TC29 or TC33
   / TC30 vs TC29 or TC33 #11
A little off topic but how much approx. would a TC#0 with FEL cost? I too am looking at buying one.
   / TC30 vs TC29 or TC33 #12
</font><font color="blue" class="small">( Have used a TC30 with 5' bush hog without any problems for more than two years now. In fact, the TC30 would probably pull a 6' without any problem, too. )</font>
I agree....weight of a 6 footer might be an issue though.
The dealer here in central N.Y. told me the TC30 9x3 $16,670 the TC30 hydro $18,100 with the 7308 QT loader
   / TC30 vs TC29 or TC33 #15
</font><font color="blue" class="small">( I doubt weight would be a problem with the TC30's 1635 lb. 3PT capacity. )</font>
Hank, I'm not sure what Roy meant, but I don't think he meant the 3PH lift capacity on the TC30. I think he meant needing front ballast to counterbalance a 6' cutter. I think you would need to leave the 7308 FEL installed or add front weight to a TC30. That would be especially true if your work included going up and down hills with the cutter lifted by the 3PH. What has been your experience with your TC30?
   / TC30 vs TC29 or TC33 #16
</font><font color="blue" class="small">( A little off topic but how much approx. would a TC#0 with FEL cost? I too am looking at buying one. )</font>
i recently got quotes for:
TC30 w/hydro and loader 15,800
TC29DA w/hydro and loader 18,350 add 1000 for supersteer
these were quotes from Corriher Implement Company
   / TC30 vs TC29 or TC33 #17
Thanks All I have to do now is some major convincing. /forums/images/graemlins/crazy.gif
   / TC30 vs TC29 or TC33 #18
Hi Jinman,
I must say I agree with the front ballast issue. I have personally not used a rotary cutter on my tractor but I do know a guy with a 6' rotary cutter and he has a TC30. He has no problem with the weight of the cutter but he does have a FEL installed. It does OK with general tall grass but larger stumps do slow it down. I personally think the 6' is to large for the PTO HP of the TC30. I don't think you will be able to use the cutter to its full potential. I wasn't trying to knock Roy's comment, I just meant that for its size the TC30 can really work it hard. /forums/images/graemlins/smile.gif
Kinze (Delgelman) MT 201 High Speed Disc (A52349)
Kinze (Delgelman)...
1 Oliver Front Weight (A50515)
1 Oliver Front...
2015 Jeep Compass SUV (A50324)
2015 Jeep Compass...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2019 TAKEUCHI TL8 SKID STEER (A51242)
2019 TAKEUCHI TL8...
2018 John Deere 524K-II Articulated Wheel Loader (A50322)
2018 John Deere...
