Buying Advice TC30 to replace old 2000
   / TC30 to replace old 2000 #1
Swampster
My old Ford 2000 (about 1964) does a decent job with a 6 foot King Kutter bush hog. Bogs down sometimes in very thick material or mowing lots of brush/trees. Can I expect at least equal performance with the TC30? It is a used 2002 model.
   / TC30 to replace old 2000 #2
I have a 2000 tC-29D that I have owned since new and I routinely bush hog 3 foot tall grass and brush and have had no problems. It has lots of power.
   / TC30 to replace old 2000 #3
You really need to compare PTO HP of your old Ford to the NH TC-30. IIRC, the TC-30 gear puts out about 23-25 PTO HP.
   / TC30 to replace old 2000 #5
You might want to look for around 40 or 45 pto hp . A used ford 3910 or 3930 has around 45 pto hp . It will run a 6 ft cutter real nice and do better on fuel than your 2000 ( unless you have a diesel engine in it ) .
   / TC30 to replace old 2000 #6
the old 2000, if a gasser could be a 134ci or 144ci diesel.. or if a later model 158ci ,my units with the 134ci, I would say put out close to 32 pto hp... I have used a 6' cutter on my 134ci engines.. and they seem to do fine with it in most areas. I can mow weeds that are taller than me with an older 8n and a 5' mower ( 27 pto hp )
soundguy
1998 CATERPILLAR 120H MOTORGRADER (A51406)
1998 CATERPILLAR...
2018 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A52576)
2018 INTERNATIONAL...
City of Lakeland (A51691)
City of Lakeland...
Sky Trak 10054 Legacy 10K Telehandler (A51573)
Sky Trak 10054...
1999 KENWORTH W900 TANDEM AXLE SLEEPER (A52576)
1999 KENWORTH W900...
2021 MDB TF150R 84" HYD MULCHING HEAD (A51406)
2021 MDB TF150R...
