Oil & Fuel TC30 Oil dripping from tube/hose
   / TC30 Oil dripping from tube/hose #1
bckskin2
Washington. IL
New Holland TC30
Help there is a tube/hose on the right side of my TC30 running from the valve cover and oil started dripping from it today. Is this bad? Time to start tractor shopping?
Jerry
   / TC30 Oil dripping from tube/hose #2
It's always time to go tractor shopping. :laughing:
That's the blowby tube. Oil can come out of it several reasons. Piston rings being one. A missing baffle in the valve cover. Fuel dilution in the oil or just too much idling.
Usually it will get worse but not quickly. Change the oil if you haven't lately and then but it to work for an hour or two.
I just changed the oil.
Any chance it will just go away?
Jerry
   / TC30 Oil dripping from tube/hose #4
How much oil are we talking about?
   / TC30 Oil dripping from tube/hose #5
Was it dripping before you changed the oil?
   / TC30 Oil dripping from tube/hose #6
Jerry[/QUOTE
Did you change the weight or brand of oil?
Unless it is really puffing or dripping a lot of oil, It isn't anything to panic about. A little smoke and an occasional drip come with a "seasoned" tractor.
And yes it may get better and it will probably vary depending on the various uses you put your tractor to.
Not a huge amount. drops.
not that I noticed.
I went from a 10w-40 to a 10w-30. About all Use it for is to move dirt occasionally, mow the pasture if it gets to tall for the ZTR and, move some snow. When we had horses we used it a lot more.
2011 New Holland Boomer 90 MFWD Utility Tractor (A52748)
2011 New Holland...
2016 Chevrolet Impala Limited Sedan (A51694)
2016 Chevrolet...
CATERPILLAR VC60DSA SHOP FORKLIFT (A52472)
CATERPILLAR...
2018 Ford F150 Eco Boost Truck (A52384)
2018 Ford F150 Eco...
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
2016 Sure-Trac 20 Ton Pintle Trailer, VIN # 5JW2U2522G1121114 (A51572)
2016 Sure-Trac 20...
