TC30 odd Noise
   / TC30 odd Noise #1
MRCONCDID
North Florida
2007 L48 Kubota
Im new here as a member but have been reading this forum for a long time
I have a noise I can't find, see what you think
It comes from the rear axle area under the seat with and without any attachments
It only makes noise when going from a dead stop or foward to revese or visa a versa
Its kind of a solid sounding squeak or knock like something is loose and as the troque changes directions it shifts, it only makes this noise once until you change directions again.
its a low pitch "erk" sound like the rops or something heavy is moving front to back
The rops are tight and so are the wheels and it is not speed or bounce related
I do not have a Backhoe so I dont have the subframe for it,
This is a manual colume shift not HST
Thank you in advance for your help
   / TC30 odd Noise #2
Tires rubbing against the 3PH arms? Sounds simple, but it happened to me! Tires hitting somewhere else? Can't really think of anything else.
Brad
   / TC30 odd Noise #3
Could it be one of the brakes are not releasing untill you move a little.
Bill
   / TC30 odd Noise
I am thinking breaks are hanging up and releaseing, how would I ajust this with out loosing brake pressure?
thanks for all your input
   / TC30 odd Noise #5
I would check the manual but my 1210's are a mechanical linkage that is adjusted but turning a nut to lengthen or shorten it.
   / TC30 odd Noise
I have been thinking it might be the breaks but it is more of a low pitch squeak, adjusting them seems to feel of the pedal not the release of the breaks, it isn't the applied pressure its the release pressure, is there a spring on the brake shoe that might have come loose, if so where in the world is it, and how would I check it?
   / TC30 odd Noise #7
To check if it's the brakes, try to apply medium pressure to the brakes while you change directions. If you don't hear any noise, it sounds like brake pads or springs rubbing. Also, you might try a few hard braking cycles to clean things up in there if you don't use your brakes much.
   / TC30 odd Noise
Its not the brakes, I ruled it out with some more seat time. I get the noise in an off camber situation or a binding position while moving or when changing directions, it must be related to the body work or the ROPS shifting but it is to low of a sound to be sheet metal , my ROPS clamp on and the lower 3 pt arms attach to them. which is why it is more noticeable with an attachment but yet is still present with out one. I will try and tighten the ROPS tonight and see if that changes anything. It might sound like a pet pev but it gets olds when using the fel back and forth with squeak/squeak.
   / TC30 odd Noise #10
I had the similar issue and as JackB noted, it was a lack of clean grease in the tube for the spline shaft. The splines get dirty and then grab until you put enough torque for the shaft to move.
VERMEER RTX 130 WALK BEHIND TRENCHER (A51242)
VERMEER RTX 130...
2014 Dodge Charger Sedan (A51694)
2014 Dodge Charger...
2012 EAGER BEAVER RGN (A53843)
2012 EAGER BEAVER...
RV Hitch (A50121)
RV Hitch (A50121)
2020 CHEVROLET W4500 16FT REEFER BOX TRUCK (A53426)
2020 CHEVROLET...
toro turf sweeper (A50324)
toro turf sweeper...
