TC30 + JD894a Side Delivery Rake + JD 14T Baler =?
   / TC30 + JD894a Side Delivery Rake + JD 14T Baler =? #1
HammerFour
Holt, Missouri
Kubota B7100, JD Gator 6X4, Kubota L2350, JD 14T Baler, JD 894A Side Delivery Rake, IH 100 Balance Sickle Mower
I just wanted to put a message up here and let you folks know that my father-in-law's TC30 worked real nicely this weekend running a JD side delivery rake and square baler. We didn't do very many bales as we had some other projects to work on, but it was a lot of fun.
I will post a picture once I get one.
- Tim
   / TC30 + JD894a Side Delivery Rake + JD 14T Baler =? #2
A square baler uses a flywheel that 'holds' about 50 hp, but only takes about 15 hp to keep it running. The plunger uses a lot of power, but only for a short period, so the 15hp input is enough.
The problem is, that 50hp flywheel can put quite a strain on a compact tractor. Many of them are not built tough enough to take this 'feast & famine' pto loading.
Probably ok for a few bales now & then, and your tractor is on the bigger end of the compact side of things so you are probably alright anyhow.
Just feel better mentioning it is all.
--->Paul
2015 FORD-750 XL SUPER DUTY DUMP TRUCK (A51406)
2015 FORD-750 XL...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
2013 MACK ELITE LEU613 GARBAGE TRUCK (A51406)
2013 MACK ELITE...
2018 New Holland TS6.120 4WD 96HP Agricultural Tractor (A50322)
2018 New Holland...
1999 Case International MX200 Tractor (RIDE AND DRIVE) (A50774)
1999 Case...
Farmall H Tractor (NOT RUNNING) (A50774)
Farmall H Tractor...
