TC30 + JD894a Side Delivery Rake + JD 14T Baler =?
   / TC30 + JD894a Side Delivery Rake + JD 14T Baler =? #1
HammerFour
Holt, Missouri
Kubota B7100, JD Gator 6X4, Kubota L2350, JD 14T Baler, JD 894A Side Delivery Rake, IH 100 Balance Sickle Mower
I just wanted to put a message up here and let you folks know that my father-in-law's TC30 worked real nicely this weekend running a JD side delivery rake and square baler. We didn't do very many bales as we had some other projects to work on, but it was a lot of fun.
I will post a picture once I get one.
- Tim
   / TC30 + JD894a Side Delivery Rake + JD 14T Baler =? #2
A square baler uses a flywheel that 'holds' about 50 hp, but only takes about 15 hp to keep it running. The plunger uses a lot of power, but only for a short period, so the 15hp input is enough.
The problem is, that 50hp flywheel can put quite a strain on a compact tractor. Many of them are not built tough enough to take this 'feast & famine' pto loading.
Probably ok for a few bales now & then, and your tractor is on the bigger end of the compact side of things so you are probably alright anyhow.
Just feel better mentioning it is all.
--->Paul
2005 Mitsubishi Lancer ES Sedan (A51694)
2005 Mitsubishi...
(3) 8' High Pole Swinging Gates (A50515)
(3) 8' High Pole...
2006 Mack CT713 Granite T/A Galbreath Roll-Off Truck (A50323)
2006 Mack CT713...
Unused 2025 CFG QK18R Mini Excavator (A50322)
Unused 2025 CFG...
2018 KENWORTH T680 SLEEPER TRUCK (A52141)
2018 KENWORTH T680...
Kubota RTV500 (A47384)
