TC30 battery draining - key will not shut off engine once running
   / TC30 battery draining - key will not shut off engine once running #1
Destr0
2019 Kioti DK6010SE 07 New Holland TC30
I replaced the fuel shutoff solenoid as it was making a click even with key off. I guess that was not the problem. Fixed it (or so I thought) for about a week. Now it is draining the battery overnight, still makes a clicking at the fuel solenoid even with key off. Will not shut off with the key. I'm thinking the ignition switch? Going to go through all the safety switches -
I have been pulling the 5 amp fuse to shut it off and keep the battery from draining.
Any ideas? Need to find my voltmeter...
   / TC30 battery draining - key will not shut off engine once running #2
You can use a test light also. t The shut off valve is a normally closed solenoid, so no power and it is closed. Switch on and it should open. you can test it with a volt meter or a test light just the same.
JC,
   / TC30 battery draining - key will not shut off engine once running #3
You can get a cheap one for $10 that will do the trick. Start at the switch.
I replaced the shutoff solenoid a couple weeks ago. I am pretty sure it is the switch- if it is the computer ($335) I am just going to wire a switch to the 5 amp fuse.
Still have not figured this out - I tried a new switch - no difference. Tractor still runs when you turn off the key. I ended up just getting a fuse circuit tap - and wring it to a switch so I still have my 5 amp fuse wired in but also an on off switch (that keeps the battery from draining and will shut off the tractor).
I also pulled the trigger and bought a 2019 60HP tractor (DX6010SE) with twice the loader capacity and twice the HP. The old tractor will just leave the brush hog attached.
2015 Chevrolet Malibu Sedan (A55853)
2015 Chevrolet...
EZ-GO Utility Cart (A55853)
EZ-GO Utility Cart...
2016 Ford F-150 Crew Cab Pickup Truck (A53422)
2016 Ford F-150...
2016 CATERPILLAR CB34B SMOOTH DBL DRUM ROLLER (A52707)
2016 CATERPILLAR...
2024 HURRICANE GF480 - 48" ROTARY DRUM SCREEN (A52706)
2024 HURRICANE...
2025 XKH39 39in Hydraulic 4-Way Clamshell Skid Steer Bucket (A55851)
2025 XKH39 39in...
