tc29da stuck in 4wd
   / tc29da stuck in 4wd #1
TractorDale
fairfield, ct
TC 29DA
Never had this problem before- tried using clutch, in and out of neutral, gently trying while moving very slow forward in low range. Not forcing it though. Thoughts appreciated. Is there a trick?
Dale
   / tc29da stuck in 4wd #2
Make sure your wheels are straight. You also can try wo lift up your front with the bucket. Gotta go!
   / tc29da stuck in 4wd #3
I agree with DieselMonk, on my 2120 quite often I use the FEL to lift some weight off the front end and it slips right out of 4WD.
Andy
   / tc29da stuck in 4wd #5
Glad you got it out.
I've had it 'bind' a few times when pulling out of the yard onto the pavement and forgetting it was in 4WD. If I back up and/or turn the other way with a bit of pressure on the lever it slides right out.
   / tc29da stuck in 4wd #6
i find if mine is being troublesome, i usually straighen up the wheels and move forward a fuz, then stop and start backing up while pulling on the lever.
usually as soon as you transtion from the stop to rev, it unloads the 4wd and the lever will slide right back....
2014 Morooka MST1500 Crawler Carrier (A52384)
2014 Morooka...
6"x8' Treated Post,  Approx. 28 Piece Bundle  (A52384)
6"x8' Treated...
43030 (A51691)
43030 (A51691)
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
RYOBI 18V BRUSHLESS ELECTRIC 20" PUSH MOWRE (A51248)
RYOBI 18V...
