Tc29da hst won't move
   / Tc29da hst won't move #1
Freddy11
Angelica
New holland tc29da hst
I have a tc29da hst and it won't move. All fluids are good and linckage is good. Pto works. Help please
   / Tc29da hst won't move #2
When was the last time your filter was changed? Will it move when your oil is cold? And dose it make a oil by passing sound when you move the pedal?
Hydro oil was just changed. New filter. When it's cold the pedal will go about halfway down and whine and flutter and the tractor moves a little. I roll the tractor back and forth with the fel and sometimes the pedal will get hard like it's supposed to and the will tractor will move fine. I discovered this by towing it in the shop the first time I started it and it wouldn't move. Don't know if the rolling it actually helps of if it just works after a while on its own
   / Tc29da hst won't move #4
Welcome to TractorByNet!
I moved your thread to the New Holland Owning & Operating forum. :)
   / Tc29da hst won't move #6
As JJ would say" Get a Gauge to measure your Hydraulics".
   / Tc29da hst won't move #7
New oil, new filter, new behavior? Could be related.
Is this the first time the temperature outdoors has been cold since the change?
Did you use the recommended hydraulic fluid and filter?
2021 Allmand Bros Maxi-Lite II 20kW Towable Light Tower (A55973)
2021 Allmand Bros...
60" HYD BRUSH CUTTER (A52706)
60" HYD BRUSH...
2025 Electric Diesel Fuel Pump with Hose Reel (A55852)
2025 Electric...
2020 MACK GR64FT (A58214)
2020 MACK GR64FT...
2015 GMC Terrain (A56859)
2015 GMC Terrain...
2017 Ford Fusion Hybrid Sedan (A56859)
2017 Ford Fusion...
