TC29D - What is this hole/bolt?
   / TC29D - What is this hole/bolt? #1
RoyK
North Central PA
NH TC29D
Under the tractor, on the center-line between the transmission drain plug and the spline shaft for the front axle there is a hole/bolt. I say that because it was a threaded hole when I discovered it, but since it is threaded, I'm assuming there should be a bolt/plug in it. I can't find any reference as to what it is in the owners manual, but I had hydro fluid leaking out of it. Can someone tell me what it is?
Roy
   / TC29D - What is this hole/bolt? #2
I looked at my TC29 and it has the same threaded hole that that yours has. Mine doesn't have any oil leaking out of it but I don't know what it is there for.
They probably use that transmission case for different tractor models besides the TC29 and that hole might be used on one of those machines.(I'm just guessing).
Does yours have a plug in it or is it open?
2014 Volkswagen Jetta Sedan (A50324)
2014 Volkswagen...
Brent 644 S/N B29820157 (A52128)
Brent 644 S/N...
UNUSED TOPCAT QUICK ATTACH HYD 4N1 COMBO BUCKET (A51244)
UNUSED TOPCAT...
2016 Takeuchi TL8 (A47384)
2016 Takeuchi TL8...
(4) 24' Stand Alone Texas Panels (A50515)
(4) 24' Stand...
2013 VOLVO VNM TANDEM AXLE DAY CAB (A52141)
2013 VOLVO VNM...
