TC29D Temperature Issues
   / TC29D Temperature Issues #1
davcon
Northern Nevada
TC29
This summer I noticed the temp was fluctuating oddly. As if the thermostat was stuck open. Found a post from Mr. jinman http://www.tractorbynet.com/forums/new-holland-buying-pricing/134391-n-h-tc35-3.html#post1573609. Cut the tab off the thermostat as suggested and parked it til this weekend. Coincidentally, now the gauge has stopped working. Grounded the gauge connector and the needle instantly rose to red. Assuming the gauge is ok, i ordered a new sender. Also getting a new thermostat just in case. Hope this does the trick.
   / TC29D Temperature Issues #2
My spade connector that hooks to the sending unit sometimes loses contact. I clean the male spade on the SU and the female on the wire end too. That normally gets the temperature gage working and staying steady. When I see lots of fluctuation, I immediately go to the spade connector and it has always proven to be the culprit. The problem is that the sending unit is a low-resistance unit. Any contact resistance in the connector is enough to cause the resistance to ground (ohms) to change enough to make a huge difference by percentage, of the total resistance. Clean contacts are imperative.
To check your sending unit, pull the spade connector off and use an ohmeter measure the resistance from the spade connector on the sending unit to ground (the engine block). Write down that reading and then start the tractor and let the engine warm up. Measure the resistance again. It should be much lower. When the engine is cool, the ohms should be around 700, when the engine warms to normal operating temperature, you should see 100-125 ohms. This simple test will tell you the condition of your sending unit without having to purchase another one new. In summary:
1. Check the spade connector for clean contacts.
2. Check the resistance of the sending unit to ground for cold and normal temperatures.
The results will determine your next steps. Good luck and save bucks $$$.:)
Jim,
Thank you. Very informative reply as usual. I'll try those steps the next time out.
Dave
   / TC29D Temperature Issues #4
Also, make sure your radiator is clean enough to see through it. Take a light and shine it from the back. You should easily be able to see through.
Jim,
I checked the resistance per your suggestion and the sensor was indeed shot. Installed a new sensor as well as the thermostat (previously it wouldn't come up to temperature) and all's well again. Thanks for the help.
Dave
2025 New/Unused 72in Wolverine Grapple Bucket (A51573)
2025 New/Unused...
2025 84in Dual Cylinder Grapple Bucket Skid Steer Attachment (A51691)
2025 84in Dual...
2018 Club Car Carryall 1700 (A51573)
2018 Club Car...
City of Lakeland (A51691)
City of Lakeland...
2025 New/Unused LandHonor 13,000lb Electric Winch (A51573)
2025 New/Unused...
