Mowing TC29D - handle a sickle bar or disk mower?
   / TC29D - handle a sickle bar or disk mower? #1
fred.hayfarm
New Holland TC29D
I need to cut tall weeds and grass hay on about 10 acres couple of times a season. Can I do it with the TC29D (I mean to ask the dealer next time he's open)? Seems a sickle bar mower would do well. What's the comparison between sickle bar and disk mowers - cost, maintenance, speed? I'm a one man operation so ease of maintenance is a big consideration. What should I look for (and look out for) in used mowers? Thanks.
   / TC29D - handle a sickle bar or disk mower? #2
You can't handle a disc mower with a tractor that size although you may be able to run a drum mower....Check with Carter & Carter (CCM). You CAN run a sickle mower with it. For 10 acres that's all you need anyway. A disc is just faster and needs a much larger tractor. Lots of used sickle mowers around. Just check the bearings, guards, knifes, wear plates, hold-down clips, etc. Even if you have to rebuild the cutter bar, it's not than expensive and it will last a very long time if maintained.
I hate to say this but if you are looking for "ease of maintenance", I'm not sure you should be thinking about haying.......
Thanks, Mike120, for the info. I figure it's all comparatively easy until it gets to the baler. That might be a cooperative or a hire in effort for a while, at least until I can move up a few notches of horsepower and have some more experience.
   / TC29D - handle a sickle bar or disk mower? #4
Good Luck! For 10 acres it's hard to justify spending a lot, but if you take your time you can find some good deals. You can find local used equipment on Used Tractors at TractorHouse.com: John Deere Tractors, used farm tractors and farm equipment, Case IH, New Holland, Agco, Caterpillar. , Used Tractors and Farm Machinery from Fastline , Craigslist, etc. I just sold a lot of my old hay equipment this year and bought new. This is the first summer in years that I haven't had to repair something.....
2014 GMC Sierra Pickup Truck (A50323)
2014 GMC Sierra...
2013 FORD F-550 SUPER DUTY XL BUCKET TRUCK (A51243)
2013 FORD F-550...
2016 Nissan Sentra Sedan (A50324)
2016 Nissan Sentra...
2019 Energreen EVO 40 Robotic Tracked Flail Mower (A52128)
2019 Energreen EVO...
2014 Doosan DA30 (A52128)
2014 Doosan DA30...
2022 BOBCAT T595 SKID STEER (A51242)
2022 BOBCAT T595...
