dlctcg
Platinum Member
@Mtsoxfan
I believe the glow plug timer has multiple connection paths... meaning...
When the key is turned to ACC/RUN position the timer should light the dash indicator light & supply ground to the glow plug power relay to energize the glow plugs ONLY for a specified amount of time, deluxe model for 4-5secs & 10-11secs on economy model, & then turn off; this is to keep from burning up the glow plugs when the switch is in the ACC/RUN position or when the tractor is running.
When the Key is turned to the START/CRANK position I believe the circuit is still completed & the glow plugs are still energized as long as you keep the key turned, this is to assist in starting, when the tractor starts & the key returns to the ACC/RUN position then the glow plugs are de-energized.
So if the glow plug timer goes bad I've read multiple different conditions it can cause... yours being one of them. Sometimes the glow plugs will get no voltage at all, ours when it went bad it did the opposite... it kept powering the glow plugs even after the tractor was started... so as your planning to do, testing is definitely your best bet.
I believe for testing you could use any 12volt source as you are just seeing if the timer is working & it is not connected to the tractor, being I had the timer disconnected I just tested it with the tractor battery (disconnected from the tractor) which allowed me to use very short test leads.
