TC29D Glow Plugs
   / TC29D Glow Plugs #1
RuT
West Unity, OH
NH TC29D FWD
I am still fighting a glow plug issue. It starts hard in the cold unless I use the block heater for a couple hours. The light on the dash for the glow plugs may or may not come on when the key is turned to the appropriate position - it is sporadic. If the glow plug light does not come on and I turn the key to the preheat position the other lights will dim.
I replaced the relay already. I checked the wire and the bar for voltage - the bar connecting the glow plugs and get 11 volts at the wire and along the bar. I put the bulb and cover from the glow plugs on the back of the dash panel in the oil sensor position and the light works fine.
Is there a way to tell for certain that the glow plugs are working? My instincts are one or more are not due to hard starting. Could I also have a light in the dash issue? Appreciate your help. It seems like I have to figure out a way to determine if the plugs are actually working somehow.
   / TC29D Glow Plugs #2
Sounds like you have power to the glow plugs. Remove the bar, then, using an ohmmeter, check the resistance between the terminal and the threads. As I remember, should be around .8-1.2 ohms.
Oil Well Pump Jack with Motor (A52377)
Oil Well Pump Jack...
2015 RAM 5500 Bucket Truck w/ Versalift SST40 boom -Cummins Diesel - Auto Trans- 4X4 - 72096 miles (A53473)
2015 RAM 5500...
2022 ALLIANCE NORTH AMERICA, INC AIRMAN SDG45 GENERATOR (A53843)
2022 ALLIANCE...
Misc. Lighting Equipment (A53117)
Misc. Lighting...
2023 NEW HOLLAND WAGON TONGUE AND LOADING CHUTE FOR NEW HOLLAND SQUARE BALERS (A53473)
2023 NEW HOLLAND...
2007 FREIGHTLINER M2 26FT CDL REQUIRED BOX TRUCK (A54607)
2007 FREIGHTLINER...
