TC29D Glow Plugs
   / TC29D Glow Plugs #1
RuT
West Unity, OH
NH TC29D FWD
I am still fighting a glow plug issue. It starts hard in the cold unless I use the block heater for a couple hours. The light on the dash for the glow plugs may or may not come on when the key is turned to the appropriate position - it is sporadic. If the glow plug light does not come on and I turn the key to the preheat position the other lights will dim.
I replaced the relay already. I checked the wire and the bar for voltage - the bar connecting the glow plugs and get 11 volts at the wire and along the bar. I put the bulb and cover from the glow plugs on the back of the dash panel in the oil sensor position and the light works fine.
Is there a way to tell for certain that the glow plugs are working? My instincts are one or more are not due to hard starting. Could I also have a light in the dash issue? Appreciate your help. It seems like I have to figure out a way to determine if the plugs are actually working somehow.
   / TC29D Glow Plugs #2
Sounds like you have power to the glow plugs. Remove the bar, then, using an ohmmeter, check the resistance between the terminal and the threads. As I remember, should be around .8-1.2 ohms.
2016 Ford Explorer AWD SUV (A53424)
2016 Ford Explorer...
2013 Chevrolet Silverado 3500HD Enclosed Service Truck (A52377)
2013 Chevrolet...
UNUSED CFG INDUSTRIAL H15R EXCAVATOR (A52706)
UNUSED CFG...
2016 KOMATSU PC360LC-11 EXCAVATOR (A53843)
2016 KOMATSU...
2011 EDMONTON TRAILER MFG FRAC PUMP (A53843)
2011 EDMONTON...
2014 GMC Sierra Pickup Truck (A50323)
2014 GMC Sierra...
