TC29D first use, FEL question
   / TC29D first use, FEL question #1
ericinmich
SE Michigan
'01 TC29D FEL MMM
I got my first use on my ’01 TC29D (bought used, 260 hrs). We are moving this spring to a new house and a 5 acre lot and since I bought it a month ago, it’s been sitting in my garage… and me looking for an excuse to use it.
I decided to use the FEL to clear the driveway. Small driveway that I normally do with a 20” snowblower in 30 minutes. It was much more fun to use Babe (my wife’s name for my toy). It didn’t take long to clear. Back dragging with float, and picking up piles was BIG TIME FUN. I’m sure the neighbors wondered what was up with a ‘real’ tractor driving around the court.
I noticed that the FEL (7308) is about an inch lower on one side vs. the other. Is this something that I’ll likely have to live with, or is there a way to adjust. I took a quick look at the FEL owner’s manual but didn’t see anything obvious, nor did I see anything on the loader arms or mounting points.
Also, I searched for this question or answer in previous TBN posts, but didn’t get much info… sorry if it’s an old story.
Thanks,
Eric
   / TC29D first use, FEL question #2
Check the air pressure in the front tires. Make sure they're the same.
   / TC29D first use, FEL question #3
Are your tire pressures equal, comparing rights to lefts?
   / TC29D first use, FEL question #4
Front axle oscillates independent of the loader frame; won't affect loader. Uneaqual rear tire pressure will cause the problem. Or several other things we don't want to get into yet.
The front's were off by ~10psi, and the rears only 2psi. I equalized them and couldn't see a difference.
My guess is that I need to take it to a level spot, and loosen up ??. I did look at the four LARGE bolts on the frame at the front of the tractor, and noticed that they don't look equal in the slots (left side to right side). Also, on side had some paint 'wear' so it may have moved (or been moved).
Am I on the right track?
- Eric
   / TC29D first use, FEL question #6
Can you post some pics?
I won't be able to take any pictures until next week (flying out of town). What area would you like pics of? Basically, the left front side of the loader is about an inch lower than the right (ie. if I lower the FEL slowly, the left corner would touch first, and the right corner would be an inch off of the ground).
Thanks in advance for the help from a great group...
Eric
   / TC29D first use, FEL question #8
<font color="blue"> What area would you like pics of? </font>
You mentioned "I did look at the four LARGE bolts on the frame at the front of the tractor, and noticed that they don't look equal in the slots (left side to right side). Also, on side had some paint 'wear' so it may have moved (or been moved)."
   / TC29D first use, FEL question #9
In addition to the front tire pressure(and rear which is just as important), I wonder about the surface you were parked on when you noticed the apparent difference in height. It's pretty hard to find a perfectly level site for all 4 wheels and the entire bucket edge to sit on. /forums/images/graemlins/confused.gif
Andy
   / TC29D first use, FEL question #10
Front tire pressure difference and mounting kit bolts being loose are the main causes. Check all the big bolts that screw into your main casting. If the bolts are even a little loose, it can make an inch or 2 difference in a hurry way out on the end of the loader.
2015 Chevrolet Tahoe SUV (A50324)
2015 Chevrolet...
2021 ALLMAND BROS, INC. NIGHT LITE LIGHT TOWER (A50854)
2021 ALLMAND BROS...
2009 Peterbilt 384 T/A Wet Kit Day Cab Truck Tactor (A50323)
2009 Peterbilt 384...
2002 JOHN DEERE 450H CRAWLER DOZER (A51406)
2002 JOHN DEERE...
2015 MACK GU713 DAYCAB (A50854)
2015 MACK GU713...
2002 International 9200i Truck (A51039)
2002 International...
