TC29D, Block Heater, Garage Door Opener
   / TC29D, Block Heater, Garage Door Opener #1
thcri
Elite Member
Minnesota SE
New Holland TC29D, 2001
My TC29D always been in the garage and no need to use the block heater. This is a Factory Block Heater. Well this yeah the tractor has to sit outside. I have a couple of cords to put together, plug into the hot outlet, open garage door and string it the cords to the tractor. About 50 feet in all. As soon as I plug into the block eater my garage door starts going down. Quick thinking I run to stop the door or I am locked out. I don't even think of it being the heater but start looking around to see if some one is playing a joke on me. No one is home so I go and unplug the heater and try and duplicate it again. No way. I use the tractor later on that day. The next day a snow storm is on the way so I go out and plug the tractor in and the door starts going down. It only does this if and only if I plug it in hot at the tractor and only less the door is open until today. My wife bought me a new 50 foot all weather 12 gauge cord that will open or close the door like 5 minutes after plugged it in. Makes no difference if I plu it in from in the garage first or last.
The tractor is parked about 30 feet from the opener.
Has anyone ran into this before. I have not really used the heater much in the past.
   / TC29D, Block Heater, Garage Door Opener #2
I've never heard of that happening. I've had similar things happen on machinery, which turned out to be electrical noise causing the problem. This was due to having three phase ran in the same conduit as 24V (never a good idea).
Have you tried using a different outlet? If you plug it in through your kitchen window, will it turn on your coffee pot? :laughing:
Chris
   / TC29D, Block Heater, Garage Door Opener #3
Be sure to wear you tin foil hat just in case...:eek:
   / TC29D, Block Heater, Garage Door Opener #4
Unless the button is in your pocket it's probably the amperage draw on heater startup causing the garage door to respond like a reset or power failure and default to whatever is opposite if the open/close position.
   / TC29D, Block Heater, Garage Door Opener #5
Anything else plugged into this circuit like a refrigerator. I'm thinking like joe that something is temporarily pulling a heavy load. Is the outlet in good shape. Is the garage attached. Maybe plug into another circuit in the house to see if problem persists.
I had my wife pick up a ne heavier duty ford. Made it worse. But I am not blaming it on the tractor or block heater any more. The other morning I woke up and the garage door was open. Block heater was not plugged in. Based on temperature in the garage I suspect it was open about an hour. Wife says she was starting and stopping the clothes dryer about then taking one shirt out at a time.
Door opener company thinks it may be in the opener. There is a history button I am to try clearing out so will do that when I get home later this week
   / TC29D, Block Heater, Garage Door Opener #7
Not sure how a heavy duty Ford will affect the garage opener but it will probably tow the tractor better.
HaHa. Heavy duty cord. Stupid iPads and auto correct. LOL
(2) Hydraulic Augers (A50121)
(2) Hydraulic...
1999 Chevrolet 1500 (A50121)
1999 Chevrolet...
2015 Kia Forte Sedan (A50324)
2015 Kia Forte...
LOAD OUT AND SHIPPING (A51572)
LOAD OUT AND...
2020 GMC 2500 HD (A50120)
2020 GMC 2500 HD...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2019 Ford F-150...
