TC29D after start run up
   / TC29D after start run up #11
I have a '04 TC33DA and the glow plugs are timed. As the dealer stated you must turn the ignition off and then back on to get the plugs to cycle again. I do not know when the ignition was changed, but and '01 I looked at was not like this.
Prior to installing a block heater, and when I do not have time to use it, I engage the glow plugs twice if temperatures are below 35 deg. It starts a little slow and coughs and sputters with some black smoke then runs ok. With the block heater it starts as though it is 40+ deg.
…Derek
   / TC29D after start run up #12
<font color="blue"> </font> I keep mine in a pole barn so I do not see any precipatation, just the cold. First, I add a de-waxer during the cold weather. I change the fuel filter each late fall at the end of October. Finally, I cycle the plugs on and off 3 or 4 times prior to start. I know they stay on even when the light is out but the surge of current probably heats the cylinder area up a bit quicker.
elb
2003 TC29DA, 7308 FEL, 72" Rhino breeze finish mower
/forums/images/graemlins/smile.gif
IF YOU BID ON AN ITEM YOU MUST PAY FOR IT!! NO BACKING OUT AFTER IT IS SOLD!! (A50774)
IF YOU BID ON AN...
Kuhns AE10 Small Square Bale Accumulator - 10-Bale Efficient Handling System (A51039)
Kuhns AE10 Small...
2018 Ford F-150 (A51039)
2018 Ford F-150...
John Deere Quick Attach Bale Spear (A50514)
John Deere Quick...
2025 Kivel 24in Forks and Frame Mini Skid Steer Attachment (A50322)
2025 Kivel 24in...
2018 WACKER NEUSON CORPORATION DBA WACKER NEUSON LTV6 LIGHT TOWER (A50854)
2018 WACKER NEUSON...
