TC29D & 914A
   / TC29D & 914A #1
JSAN127
I have a TC29D and would like to add a belly mower. Will a 914A 54" fit my tractor.
   / TC29D & 914A #2
JSAN127:
Welcome to TBN and the Blue Forum :D! I checked my Sales and Marketing literature and it appears the 914A 54" side discharge MMM will not fit but the 60" and 72" models will. Jay
   / TC29D & 914A #3
JSAN127:
The attachment is a scan of attachment compatibilities. Jay
   / TC29D & 914A #4
A 914A should be a good combination with your TC29D. Be sure to make sure the deck is compatable with your tires. The 914A is made for many NH applications so make sure you order the correct deck and lift kit. Check the bolts often the first few hours and I would encourage you to Permatex the gear box mounting bolts before the deck is mounted (or ask the dealer to). One of the advantages of a belly mount deck is getting in tight spots. If you have a loader and leave it on, that will negate the advantages and add alot of weight to the front tires. Also, think about what tires you use. Ag tires or any non-turf tire will damage turf in wet conditions. We have two tractors with 914A decks and have been pleased with both decks, just keep up on the preventative maintenance.
   / TC29D & 914A #5
I've got the 29D with a 60" 914A. I'm sure that the manuals/specs show either the 60" or 72" mower. Sometimes I'd wish I had the 72"...
I'm not sure if a 54" would fit, and even if it did I probably wouldn't cut wider than the tires...
(1) HD 24ft Free Standing Corral Panel with 7ft Gate (A51573)
(1) HD 24ft Free...
2008 KALMER 4X2 SPOTTER TRUCK (A51247)
2008 KALMER 4X2...
7ft Dozer Blade Skid Steer Attachment (A51573)
7ft Dozer Blade...
2022 New Holland Powerstar 90 Tractor with Loader (A51573)
2022 New Holland...
2021 John Deere 310SL Backhoe (A53342)
2021 John Deere...
