TC29 tach and fuel needles
   / TC29 tach and fuel needles #1
tulloss
King Geroge, VA
NH TC-29, Farmall H
I have a New Holland TC29, and the tach and fuel gauge needles have fallen off. I put them back on once, but after a short while, they came off again, and came apart (sun/UV rot), so I cannot put them back on.
My instrument cluster works. Has anyone found replacement instrument cluster needles? I have tried some of the automotive needles, and they all use a much bigger post than the New Holland gauges.
   / TC29 tach and fuel needles #2
I shattered the hub on TC33DA's tach needle when testing gauges and built it back up with Bondic adhesive (UV-hardening).
To re-drill it for the shaft I didn't have a small enough orifice bit by .005" or so, so I added more adhesive in tiny amounts until it pressed on and stayed put.
I bet I could have rejoined a broken arm on that needle with the UV stuff. A four second cure time isn't much of a wait, so do-overs aren't a drudge.
btw, all was for naught, the whole cluster is toast, and gauges were going way off. (fuel, tach) I just run a jumper from the battery to fuel solenoid to operate, and I'm adding a Hall effect digital tach. Out of the blue, tach pegged at any rpm and fuel gauge said 3/4 when it overflowed, prompted evaluation. Switches, relays, diodes and GP timer checked out.
Messick's would have had a new IP for $1100, but '04 parts are getting scarce. Needles swing wildly, but starter and lights etc work with key on. If our stuff was a few years newer I hate to think what we might pay to service or replace electrical bling. Good luck and don't rule out fabbing a needle yourself. ;)
2025 Swict 78in Bucket Skid Steer Attachment (A53421)
2025 Swict 78in...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A53422)
2013 Ford F-150...
John Deere 5090E Tractor with Loader Prep Package, 2 Rear Remotes, Warranty Until 2028 (A55302)
John Deere 5090E...
2000 GMC C7500 SINGLE AXLE VOCATIONAL TRUCK (A56129)
2000 GMC C7500...
2017 Ford Explorer AWD SUV (A55853)
2017 Ford Explorer...
2020 CHEVROLET SILVERADO 3500 HD FLATBED TRUCK (A57192)
2020 CHEVROLET...
