TC29 tach and fuel needles
   / TC29 tach and fuel needles #1
tulloss
King Geroge, VA
NH TC-29, Farmall H
I have a New Holland TC29, and the tach and fuel gauge needles have fallen off. I put them back on once, but after a short while, they came off again, and came apart (sun/UV rot), so I cannot put them back on.
My instrument cluster works. Has anyone found replacement instrument cluster needles? I have tried some of the automotive needles, and they all use a much bigger post than the New Holland gauges.
   / TC29 tach and fuel needles #2
I shattered the hub on TC33DA's tach needle when testing gauges and built it back up with Bondic adhesive (UV-hardening).
To re-drill it for the shaft I didn't have a small enough orifice bit by .005" or so, so I added more adhesive in tiny amounts until it pressed on and stayed put.
I bet I could have rejoined a broken arm on that needle with the UV stuff. A four second cure time isn't much of a wait, so do-overs aren't a drudge.
btw, all was for naught, the whole cluster is toast, and gauges were going way off. (fuel, tach) I just run a jumper from the battery to fuel solenoid to operate, and I'm adding a Hall effect digital tach. Out of the blue, tach pegged at any rpm and fuel gauge said 3/4 when it overflowed, prompted evaluation. Switches, relays, diodes and GP timer checked out.
Messick's would have had a new IP for $1100, but '04 parts are getting scarce. Needles swing wildly, but starter and lights etc work with key on. If our stuff was a few years newer I hate to think what we might pay to service or replace electrical bling. Good luck and don't rule out fabbing a needle yourself. ;)
2015 John Deere 410E (A50322)
2015 John Deere...
2016 Ford Fusion Hybrid Sedan (A50324)
2016 Ford Fusion...
2012 Ford Edge SUV (A50324)
2012 Ford Edge SUV...
2014 John Deere 644K Articulated Wheel Loader (A50322)
2014 John Deere...
2020 Cat 299D3XE Skidloader (RIDE AND DRIVE) (A50774)
2020 Cat 299D3XE...
