TC29 3 PT hitch help needed
   / TC29 3 PT hitch help needed #11
Re your pto shaft. The telescope section needs greasing, it looks dry. Also when did the universal joints get greased last?
I did not notice that, but yeah, dry as a bone, and I bet the U joints are dry too.
   / TC29 3 PT hitch help needed #12
After you get PTO shaft cleaned up and greased you might consider replacing the yellow plastic cover around shaft. Cover keep dirt and debris out of grease and keep things and people from getting caught up in spinning shaft. I think they can be sourced thru Tractor Supply and implement dealers. You might just buy a complete new shaft with guards, chains, etc. cheap insurance
http://www.vapormatic.com/content/news/see-the-dangers-of-an-unguarded-pto-shaft.ashx
   / TC29 3 PT hitch help needed #13
I'm of the opinion that the cover on a rotary cutter PTO shaft is a waste of money. Nobody should ever have a reason to get anywhere near to a rotating shaft on a rotary cutter. It's not like a post-hole auger or chipper where you work close to an operating shaft. I think the same way about a tiller or other piece of PTO driven equipment. It's my opinion for what it's worth. Some safety features are overkill in my estimation. The points about lubing the shaft are valid, but I can't be sure the U-joint isn't greased. I'm not sure that Ridgewalker has had the mower or tractor very long.
One thing for sure, the extendable arms on the 3PH need lots of attention. Don mentioned that the "dust cover" was missing off the left side. That is NOT a dust cover. It is a spring loaded release sleeve that operates the bolt that drops into the slot on the extendable arm section. The front of the cover has a spring under it. You press down on the front of the cover and it pivots on the front pin and raises the locking bolt out of the slot. When you release the sleeve, the spring pushes it back up and locks the extendable arm when it moves forward to the operating position. Don's left side extendable link must be locked in place or the locking bolt is loose enough to move up and down by hand. If that's the case, only gravity and weight of the bolt is holding it in place. I can see on the left arm that the front pivot pin is completely gone as is the sleeve and spring. See the illustration below.
Now we're cookin' on the front burner...I am missing the springs. I couldn't figure out what held the assembly in the correct position
and it has to be the missing springs. Thanks Jinman!
PS, I will be greasing the PTO.
INOP Yamaha Timberwolf Four Wheeler (A57453)
INOP Yamaha...
2023 MADJAX GENESIS 300 ELECTRIC CART (A57192)
2023 MADJAX...
2019 Ford F-150 4x4 Ext. Cab Pickup Truck (A56858)
2019 Ford F-150...
Lee Boy 250 Gal Tack Distributor (A53317)
Lee Boy 250 Gal...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2007 Western Star 4900 SA Tri-Axle Wet Kit Day Cab Truck Tractor (A56858)
2007 Western Star...
