Tc25d won't start
   / Tc25d won't start #1
Doug4speed
New Holland tc24d
I'm new here and I have a problem my TC 25 will not start new starter turns over fine no start starting fuild still no start GLO plug light comes on battery is good don't know what else to try any help would be very appreciated
   / Tc25d won't start #2
First I would stop using starting fluid as I've heard it is not good at all for a diesel engine.
Hopefully others will reply as I can never remember the scenario which will allow your starter to turn over the engine but not allow it to start.
It's probaly something safety related like the gear selector switch so it thinks your trying to start it in gear, the PTO switch so it thinks your trying to start it with the PTO engaged. I don't think its the seat switch as from my memory if your not in the seat the starter will not engage at all.
One easy check is to make sure you are in natural with the parking brake on then try to wiggle the PTO lever and your gear selector and bounce up/down in the seat while you are cranking the engine. Next you would probably need a volt meter to start checking voltages and contacts.
What was the last time you started it and what were you doing with your tractor that last time, maybe a wire got disconnected from underneath?
   / Tc25d won't start #3
Check air filter and ducts for blockage. Verify fuel quality and if it is getting to the injector pump. Maybe the fuel stop solenoid on the injector pump stopped working or is weak. That would make it act like no fuel is getting to the cylinders and it is a common "issue".
   / Tc25d won't start #4
Be sure fuel is getting from the tank to the fuel filter. Sometimes there will be a blockage at the fuel tank outlet. Try cleaning or changing the fuel filter. Bleed the system per manufacturer instructions. Check the fuel stop solenoid as Ruffdog suggested. The problem does sound fuel related. Be sure your air filter is clean and the path to the intake manifold is clear.
   / Tc25d won't start #5
If you used starting fluid with glo plugs, it will probably NEVER start as you lunched the motor.
   / Tc25d won't start
This tractor was only a year old when I purchased it have never had any problems with it I've never had to be in the seat to start so the original owner must have took care of that safety switch . I think it is a 2002 just put new battery in it really turning over good replaced fuel filter got air out of lines stoped bubbling still won't start. I would like to pull spark plug out to see if I'm getting fire but can't find it
   / Tc25d won't start #7
Doug, a diesel engine ignites the air fuel mixture by compression. .. no spark plug.
If you didn't run the machine out of fuel, or have a clogged fuel filter, probably a fuel delivery problem.
I had a TC29da for 20 years. If you ran it low on diesel, it was obvious, it would spit sputter badly.
   / Tc25d won't start
I know it doesn't have spark plugs my attempt at humor. New battery tonight still will not start. Never ran out of fuel but the fuel that was in the filter and bowl was nasty so I drained most of it out of tank filled with new fuel at $4 a gallon and its looking pretty nasty again going to drain it out again. Can anyone tell me where the fuel solenoid is?
   / Tc25d won't start #10
If you have nasty fuel, that has to be fixed first. Then you must bleed the supply to the injection pump per instructions.
Agway Bale Accumulator (A50515)
Agway Bale...
1973 CATERPILLAR 988 LOADER (A51222)
1973 CATERPILLAR...
New Kivel 4200 lb. Skidloader Forks (A50774)
New Kivel 4200 lb...
2016 GENIE GTH1056 TELESCOPIC FORKLIFT (A51242)
2016 GENIE GTH1056...
Walking Floor Trailer 43ft (A50322)
Walking Floor...
Walking Floor...
