TC25 won't start
   / TC25 won't start #1
HeavyToy
Chelsea, Alabama
New Holland / TC25
I have just changed the fuel filter as the rngine seemed to be bogging down on steep inclines and I thought that the fuel flow was fowled. After changing the filter, the engine cranked up and idled as I rolled back from my garage and then the engine stalled. There is flow through the filter and out the tube exiting the filter under gravity. However, there is no increase in the rate of flow when the engine is being turned over. Is this a fuel pump issue? Air in the lines? Sediment in the injectors?
HeavyToy
   / TC25 won't start #2
You were having trouble before changing the filter. Not sure what that was, from the info. However, you may need to bleed the injection system to get it started.
I don't know about the 25, but on my 33 there is a bleed screw that you have to open until diesel begins to flow out of it. Then you can close that and try starting it. I have had to do this sometimes twice because I did not let enough diesel bleed out. It may run rough for a few moments but should clear out. IF that is what is keeping it from starting. I don't know if there is a transfer pump on the 25 but on my 33 it is gravity fed. On at least one occasion I had to break the injection lines one at a time to get it running smooth faster. Hope that helps some. In addition, check underneath to see if any wires are unplugged. You may have sucked some sediment or water into the system too if it was not running well.
   / TC25 won't start #3
To the original poster. if you do bleed the lines.. watch out for the high pressure ones.. don't get your hands near them.. only tools... Diesel injected under the skin = a bad infection and hospital time..
Soundguy
   / TC25 won't start #4
Look closer at fuel system, don't forget to check to see if outlet at tank is blocked. There is a shut off valve on mine. Look to see if its open all the way (if it has one). Greg
   / TC25 won't start
Can you discribe where I would find the system bleed screw/valve. A picture would be even better. I am assuming that it would be between the fuel filter and the injectors. I would guess that if the 33 is gravity fed, then the 25 would be also. There was no pressure when the engine was turned over with the line disconnected. There was plenty of flow out of the filter egress. I will look for bleed screw, but if that is not it what do I need to do to get the injectors unfowled?
   / TC25 won't start #6
There is no fuel pump between your tank and filter. If there is flow, it will remain the same during engine starting/running. I think your problem is that you got some air into the injector pump and the system needs bleeding as others have posted.
   / TC25 won't start
Can you discribe where I would find the bleed screw for the fuel injection. I am sure that the 33 and the 25 are roughly similar. I believe that my system is also gravity fed as there was no increase in pressure when I turned the engine over while the lines were disconnected. A picture would be even better.
If I have to unfowl the injectors, what will be involved in doing that?
   / TC25 won't start #8
As I said, I don't know as to the 25, but on the 33 it is on the top of the injection pump itself. And please, as soundguy said, be VERY careful of the injectors IF you do have to break the lines loose. The pressures are so high like he said, it will penetrate skin a very dangerous thing. That said, really if you can get it running at all from the bleed screw it will more than likely smooth out on its own. On my pump I forget it takes a 13 or 14 mm wrench. Senility taking over here haha. Be sure that you get it tightened up enough it won't leak once you get it running. When I bleed the injectors I just crack the lines enough to let some fuel run out and then tighten them back.
   / TC25 won't start
Thanks for your earlier input, as it sounded accurate enough. I was affraid that the air might have been at the highest point, being at each injector. So, I just cracked each injector, one at a time, and turned the engine over on each until the engine began to crank. Then I thightened them all back up and the engine cranked and ran fine. Thank you for the guidence.
   / TC25 won't start #10
Chalk that one up to learning experience. generally.. once you run a diesel dry, and have to bleed it.. you usually don't forget to fuel it after that. Pretty much only time you may have to bleed after that is with filter or fuel tap / parts changes.. etc. ( stuff you can't avoid. )
Soundguy
2011 Kubota R520S 4WD Articulated Wheel Loader (A51691)
2011 Kubota R520S...
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
2025 New/Unused Wolverine Hydraulic Skid Steer Pallet Forks (A51573)
2025 New/Unused...
New/Unused CFG Industrial H15R Mini Excavator (A51573)
New/Unused CFG...
2025 New/Unused Wolverine Clip on Pallet Forks (A51573)
2025 New/Unused...
2013 Audi Q7 AWD SUV (A51694)
2013 Audi Q7 AWD...
