TC25/29/33, I'd like to see a FEL detached
   / TC25/29/33, I'd like to see a FEL detached #1
Mosey
Conifer, Colorado
2000 New Holland TC29D with 7308 FEL, and top & tilt. 1950 John Deere B. 1940 Farmall A.
TC25/29/33, I\'d like to see a FEL detached
I would like to see a picture of the right hand side of a Boomer (TC25, TC29, or TC33) with the factory control valve and the loader detached. Does anybody have one?
I called my dealer and he doesn't have one in right now for me to look at. He said that the mounting brackets that are left on the tractor consists of a bar that sticks straight out about 18" on each side in front of the pedals and the front bracket. He couldn't remember if the front weights would be in the way of the front bracket or not. He said when he gets one in he would give me a call.
   / TC25/29/33, I'd like to see a FEL detached #2
Re: TC25/29/33, I\'d like to see a FEL detached
Danny, attached is a picture of the 'bar' your dealer was referring to where the hoses attach. This stays on the tractor when the loader is off as do the circular supports that the bottom of the loader frame rests on.
I'm not sure what he was referring to by the 'front bracket'. There's nothing on the front of the tractor that stays on when the loader is off. He may be referring to the part that serves as the loader stand, but this also comes off with the loader. See lower picture. This might interfere with front weights, although I can't verify since I do not have front weights.
   / TC25/29/33, I'd like to see a FEL detached #3
Danny, Im new here and you post is a couple of weeks old. The picture of the one guy that did reply is kind of a bad picture. I have a TC29D with a loader. If you want a picture with the loader off I can take one the next time I take mine off. There is a bar just in front of the pedals that does stick out but does not bother operation without the bucket at all. There is also a similar bar in the front end of the tractor that the loader locks on to also. It is not as large as the back ones. If I had a picture I would just send.
Murph
I got a chance to see a TC30 detached, but not a TC25/29/33, so any pictures of a TC29D would be great!
   / TC25/29/33, I'd like to see a FEL detached #5
Mosey, two things;
1. I was wrong, there is a piece that stays on the front of the tractor (see attached bad /w3tcompact/icons/smile.gif picture - be sure to click on Expand to regular size so you can read the text I added) I've also included a few other shots of the supports.
2. Just curious, what questions(s) do you have that will be answered by seeing the supports without the FEL mounted? Perhaps one of us can answer them.
I'd take my FEL off, but not when it's in the mid-twenties with no heated garage! /w3tcompact/icons/laugh.gif
   / TC25/29/33, I'd like to see a FEL detached #6
I'll second the call for a picture. I had a 7308 installed on my 25D early this winter and have not had it off yet.
   / TC25/29/33, I'd like to see a FEL detached #7
I hope this works out. There is a bunch of pictures here. Not sure on how long they will take to download. As far as removing the loader, it is a two minute job. You pretty much can do everything from the tractor except unhook the hydraulic hoses. I take mine on and off all of the time. Especially with a mower, it makes it much easier to lift the front wheels.
   / TC25/29/33, I'd like to see a FEL detached #8
Sorry, to new to this and my pict's are too large, can't send three in one.
   / TC25/29/33, I'd like to see a FEL detached #9
wished i knew how to combine
   / TC25/29/33, I'd like to see a FEL detached #10
this might work better
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2008 Ford F-750 Crew Cab Pro Patch TCM-425-135 Asphalt Patcher Truck (A51692)
2008 Ford F-750...
Toro Workman Utility Cart (A51694)
Toro Workman...
2007 JLG SkyTrak 10054 10,000lbs 4x4 Rough Terrain Telehandler (A50322)
2007 JLG SkyTrak...
