Oil & Fuel TC24DA hydraulic oil
   / TC24DA hydraulic oil #1
Mark.B
Recently purchased a TC24DA with about 217 hours on it. It was last serviced at 161 hours. I changed the motor oil and filter but have not changed the hydraulic oil or filter.
Tractor also has a 12LA loader
My question is where do you check the hydraulic fluid level? I've looked everywhere and can't seem to find any other dipsticks other than the engine oil.
I would check the owners manual but have not received my replacements from New Holland.
Is this a sign that I need glasses or am I completely missing something???
Thanks
   / TC24DA hydraulic oil #2
Your tractor should be the same as my TC18. Look in front of the seat. There should be a knob on the floor of the tractor. This will let you check your hydraulic fluid. To fill it look between the lift arms behind the seat just above where the top link connects.
Solo
Thank you solo, if it ever quits raining I will check that out!
2021 HAMM HD+9I VO DOUBLE DRUM ROLLER (A51246)
2021 HAMM HD+9I VO...
2025 New/Unused Wolverine 72in Skid Steer Hydraulic Rotary Tiller (A51573)
2025 New/Unused...
JOHN DEERE 9650 COMBINE (A51247)
JOHN DEERE 9650...
2017 Bobcat S70 Compact Wheel Loader Skid Steer (A51691)
2017 Bobcat S70...
UNUSED RAYTREE RMPP680 HYD POST POUNDER (A51248)
UNUSED RAYTREE...
2002 Kenworth T800 Truck, VIN # 1XKDD49X72J898126 (A51572)
2002 Kenworth T800...
