TC24D I'm thinking Clutch issue
   / TC24D I'm thinking Clutch issue #1
jwstewar
Elite Member
South Central Ohio
Kubota L3301
This season has been off to a rough mowing season start because of MMM issues, I think I finally got those worked out only to have the tractor bite me now.
I was mowing today, I stopped to clean the radiator and when I went to get back on, I couldn't engage the MMM - the gears kept grinding. I know I shouldn't have, but I finally got it jammed in gear and I proceeded to mow for another half hour or so. I then stopped to add some fuel. I then couldn't engage the mid-PTO at all - it was grinding really bad. So I kept playing around and as it turns out, even with the clutch pedal all the way depressed (and the mid and/or rear PTO engage) the PTO shafts will still spin. If I have the hydrostat in a range, even with the clutch pedal pushed in and I push the hydro pedal, the tractor will move. I tried adjuster the clutch pedal, but it hasn't seem to make much of a different either way. The clutch "feels" good.
Any thoughts? I'm thinking the fingers on the clutch disk have broken not allowing the clutch to disengage. Last year I had to split the tractor because of a leak at the hydrostatic pump, but everything has been fine for almost 200 hours since then. This is sounding like it is going to be a bigger harder split because I have to split the tractor forward of where I had to split it last year.
2014 BMW X1 AWD SUV (A56859)
2014 BMW X1 AWD...
2014 Ford Fusion AWD Sedan (A56859)
2014 Ford Fusion...
2014 GMC Terrain SUV (A56859)
2014 GMC Terrain...
2016 INTERNATIONAL 4300 26FT BOX TRUCK (A56129)
2016 INTERNATIONAL...
2012 Chevrolet Express 3500 Passenger Van (A55973)
2012 Chevrolet...
2015 Ford Escape SUV (A56859)
2015 Ford Escape...
