TC21D PTO question
   / TC21D PTO question #1
Baub
Western New York
NH TC21D JD425
Is the rear PTO live, or independent on this tractor? Reason I ask is, I just got a used brush hog, and want to know if I need an over-running coupler.
Thanks in advance for any help.
   / TC21D PTO question #2
I'm assuming since it is a "D" it is a hydrostat. I always get my terms mixed up, :eek: I think it is called independent. In any event you don't need an overrunning clutch. When you push the clutch in, the cutter will spin free. You can then disengage the PTO and let the clutch back out and continue on about your way.
   / TC21D PTO question #3
Baub:
Welcome to TBN :D!. If you have HST I believe your rear PTO is "live". I do not believe that you need an over-running coupler for your rotary cutter. I would make sure that you have the correct size shear bolts for and/or your slip clutch is adjusted on the RC. Jay
   / TC21D PTO question #4
Thanks Jay. We said the same thing. I just had my terms confused.:eek: I said that I always get them mixed up.:cool:
Thank you both for the help!
   / TC21D PTO question #6
Baub & jwstewar:
Da Na Da :D! We are all in this together :)- Jay
2025 20ft. G70 Cargo Transport Chain (A51692)
2025 20ft. G70...
2017 Currahee Trailers Trailer, VIN # 4TEFS1826H1034878 (A51572)
2017 Currahee...
UNUSED RAYTREE RMSC78-78" SOIL CONDITIONER (A51248)
UNUSED RAYTREE...
2025 New/Unused Wolverine Clip on Pallet Forks (A51573)
2025 New/Unused...
2019 Fontaine Traverse HT T/A 48ft. 41 Ton Hydraulic Dovetail Equipment Trailer (A52377)
2019 Fontaine...
(1) VISSANI REFRIGERATOR (1) FRIGIDAIRE REFRIGERAT (A51248)
(1) VISSANI...
