TC21d leaking oil on MMM.
   / TC21d leaking oil on MMM.
Larry, I'm not sure about exact line , that you are talking about. I'm no mechanic. I can't believe the dealer can't fix this problem for you. I would be upset. My leak was in a oil cooler line which is located under the clutch toward the engine. I was told that the line was not high pressure. I hope things work out for you. There has got to be a way for them to fix that tractor. Good Luck. Kent
   / TC21d leaking oil on MMM. #12
They found the leak...its the top of front hub. Its cracked/w3tcompact/icons/frown.gif and thats why it keeps leaking. They got the parts ordered and i should have her back in a few days. Im suprised the whole thing didnt let loose. This has gone on over 3 months and i have used the tractor some in between back and forth to the shop. Hope this does it. Plus when they went to start it it wouldnt start. The saftey switch on the pto lever is out of wack again. They adjusted it last time it was in and its doing it again./w3tcompact/icons/smile.gif I hope we dont get pounded with snow the next few days, my luck we will and ill have to shovel.Larry
Larry, I'm glad they found your problem. Maybe they should have loaner tractor for us. I just got my PTO levers fixed yesterday. I hope it stays in shape for a bit. Good Luck Kent.
   / TC21d leaking oil on MMM. #14
I got my tractor back this morning. Brand new hub on her now. Lets see if she hold fluid now. My dealer, the wize guy that he is asked me if i would like to be an abuse beta tester for his dealership.../w3tcompact/icons/laugh.gif I said sure. He said the pay is great and i get a new tractor to try and wreck each month. He was kidding of course, but i am up to it. Well time will tell how she holds up. Larry
Great to Hear Larry. Now you should get to have a little fun. I had mine out yesterday, moved that topsoil pile again, and turned my wife's compost pile with it. I'm starting to get the hang of the FEL. No sign of leakage at all. Where did you say you could sign up for that beta testing???? I'm sure a new user like me would be a great tester. Then again maybe not!!! LOL Thanks again to all for the advise. Good Luck Larry. Kent
Trying signature. See if this works.
Last one was too big. What do you think of this one guys? It's made from a photo of my tractor. Using Adobe, the eraser option is very hard to master. Kent
Problems with Geocities. The doggone thing wasn't showing up. Anyone else have that problem?
TICO 510 S/A SPOTTER TRUCK (A54756)
TICO 510 S/A...
2009 International 7400 Altec A77-TE93 92ft. Material Handling Bucket Truck (A55973)
2009 International...
2004 Ford Explorer Sport Trac Pickup Truck (A56858)
2004 Ford Explorer...
MAHINDRA 3650P TRACTOR (A58375)
MAHINDRA 3650P...
2012 Kenworth T800 T/A Day Cab Truck Tractor (A55973)
2012 Kenworth T800...
2013 CATERPILLAR 316EL EXCAVATOR (A52709)
2013 CATERPILLAR...
