TC18 to mow?
   / TC18 to mow? #1
Anonymous Poster
Epic Contributor
I have one acre to mow. Will the TC18 with a 60" mower make a good mower. How is the manueverability? Does it make sense to own one for just mowing?
   / TC18 to mow? #2
makes perfect sense if that is what you want! /w3tcompact/icons/smile.gif
   / TC18 to mow? #3
The TC 18 will do the job but you might want to consider the BX 1800 or 2200 from Kubota.
   / TC18 to mow? #4
Why? I am curious as to what the Kubota's have that the NH doesn't? I am thinking about a TC18 or 21 for mowing as well but wonder if you have insight as to a problem with them for mowing or why the Kubota is better suited for mowing. Thanks.
   / TC18 to mow? #5
"Why? I am curious as to what the Kubota's have that the NH doesn't?"
Size...the BX tractors would be well suited for cutting 1 acre.
As small as the TC18 is, the BX is smaller.
   / TC18 to mow?
I have a TC18, good machine. I use the side discharge 60" MMM and it does a good job. No problems and nearly 400 hours. I had my dealer do the 300 hr service with free pickup and delivery. I went with the side discharge so I could use the Trac-Vac lawn vacuum.
   / TC18 to mow? #7
Would the BX be equal in size to a garden tractor then. It is hard to imagine something smaller then a TC 18. I am trying to decide if a TC 18 or 21 is better for what I am thinking or to just go a different route and buy a zero turn. The machine will be used only for mowing and with the TC I can use a carrier to carry extra fuel and a push mower to our other apartments around town. I am sorry for jumping on this thread but since it is the same thing I am going thru it intrigued me. I have around 1.25 acres of yard in town to mow and 3 acres here that is yard. The only other thing I would probally do is add a snow blower for keeping the driveway's clear at the apartments.
   / TC18 to mow? #8
<font color=blue>"The only other thing I would probally do is add a snow blower for keeping the driveway's clear at the apartments."</font color=blue>
It sounds like what you need is a zero turn mower, not a tractor. I'm no expert in those kinds of mowers, but my neighbor has a Grasshopper he uses for doing commercial lawn mowing. He has the vacuum system on it, and during the winter I've seen him with a snowblower, a broom, and a blade - uh - at different times of course! /w3tcompact/icons/wink.gif He hauls the whole rig on a 12' landscape trailer. That's the kind of outfit it sounds like you need.
   / TC18 to mow? #9
I was thinking the same thing but am trying to get both the pros and cons of both setups. Thanks.
   / TC18 to mow? #10
Just my two cents, but I've got a TC21D, and it couldn't be better to mow my 3 acres. The only things to think about are overhead clearance (Trees, and such), and how much stuff you need to mow around. I have a MMM, and I can get pretty close to everything with it. I do have some smaller trees on the property , that I most trim under. I couldn't get under them right with my Wheelhorse either. As far as the BX goes, that may be an option to think about. They are a bit smaller, and may make it easier to use in your yard. My problem with the zero turn mowers, is all you have there is a mower. That's fine if all you want to do is mow grass, but I found all kind of uses for my Compact. And the FEL is a back saver. Good Luck. Kent
Westfield 80-51 Transport Auger (A50774)
Westfield 80-51...
Skid Steer Quick Attach Jack Hammer (A50515)
Skid Steer Quick...
John Deere 6420 Loader Tractor (A50514)
John Deere 6420...
2017 CATERPILLAR 304E2 EXCAVATOR (A51242)
2017 CATERPILLAR...
2016 FORD EXPLORER (A51406)
2016 FORD EXPLORER...
Vermeer WR-20 8-Wheel Rake (A50774)
Vermeer WR-20...
