TC18 SN/Date of Manufacture & Hydro Leaks
   / TC18 SN/Date of Manufacture & Hydro Leaks #1
goffdl
Folks,
I just bought what I thought was a 'new' TC18 FWD Hydro w PS. Serial number is UD33564. The machine had 4 hours on the lot before they added the FEL and prepped for delivery. It was weathered a bit. It has been back twice with leaking hydro fluid. Once out of the front/back control pedal shaft and the second out of the right rear brake cover.
Has anyone had similar leaks ?
Did I get a lemon or just a machine that wasn't serviced correctly before delivery ?
Should I trade it back in on a new tc21 ( I have in writing that I will get full sales price value on a trade) ?
Thanks !
Moose
   / TC18 SN/Date of Manufacture & Hydro Leaks #2
There is an NH dealer or two on here that can give you the answer based on S/N. If I had my manual here I could give you the cut off S/N on the older/newer TC18.
   / TC18 SN/Date of Manufacture & Hydro Leaks #3
I had a leak at the pedal. Also somewhere on the rear end - not sure if it was the brake cover.
Both very minor (no drips on floor, just "wet" on tractor). Both covered under warranty.
2008 UTILITY VS2DX DRY VAN TRAILER (A54607)
2008 UTILITY VS2DX...
2014 MAGNUM PRODUCTS LIGHT TOWER (A52472)
2014 MAGNUM...
ITEM LOCATION LOT NUMBER 3 (A53084)
ITEM LOCATION LOT...
BUSH HOG 2820 LOT NUMBER 125 (A53084)
BUSH HOG 2820 LOT...
2008 CATERPILLAR 725 OFF ROAD WATER TRUCK (A51406)
2008 CATERPILLAR...
UNUSED Tool Set (A53117)
UNUSED Tool Set...
