TC18 manual transmission
   / TC18 manual transmission #1
Anonymous Poster
Epic Contributor
Is there as much changing of transmission/gear fluid on a manual transmission as there is on a hydro? I didn't know if there was a difference between the two transmissions for scheduled maintenance intervals. I would think there wouldn't be as much maintenance on a manual versus a hydro? Thank you for any information.
   / TC18 manual transmission #2
Arthurb
Looking in the book, there is no difference in the interval for transmission oil between the manual and the hydro. They both should be changed every 300 hrs.
Solo
   / TC18 manual transmission #3
The main reason that modern standard transmissions need changed that often is that the entire hydraulic system is run off of the transmission fluid also.
2022 Caterpillar 906M Compact Articulated Wheel Loader (A56857)
2022 Caterpillar...
NEW Wolverine 72in Skid Steer Tiller (A59000)
NEW Wolverine 72in...
17307 (A55853)
17307 (A55853)
LOT: (6) Grease Guns (A59076)
LOT: (6) Grease...
NEW Skid Steer 72'' Sickle Bar Mower (A59000)
NEW Skid Steer...
2013 PETERBILT 367 DAYCAB (A58214)
2013 PETERBILT 367...
