TC18 manual transmission
   / TC18 manual transmission #1
Anonymous Poster
Epic Contributor
Is there as much changing of transmission/gear fluid on a manual transmission as there is on a hydro? I didn't know if there was a difference between the two transmissions for scheduled maintenance intervals. I would think there wouldn't be as much maintenance on a manual versus a hydro? Thank you for any information.
   / TC18 manual transmission #2
Arthurb
Looking in the book, there is no difference in the interval for transmission oil between the manual and the hydro. They both should be changed every 300 hrs.
Solo
   / TC18 manual transmission #3
The main reason that modern standard transmissions need changed that often is that the entire hydraulic system is run off of the transmission fluid also.
Brent 876 Grain Cart (A50774)
Brent 876 Grain...
2022 Mack MD Danco 12R22 22FT Rollback Truck (A50323)
2022 Mack MD Danco...
KJ 42'x30' Metal Storage Shed (A50121)
KJ 42'x30' Metal...
2017 Ford Escape AWD SUV (A50324)
2017 Ford Escape...
KONE CRANES SMV-25-1200 HEAVY LIFT FORKLIFT (A52472)
KONE CRANES...
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
