Tc18 loosing power hst and hydraulics
   / Tc18 loosing power hst and hydraulics #1
Hollyblue
New Holland tc18
My tc18 ran fine till yesterday when I started loosing power in the hydraulics and HST at the same time after heavier use. Related or not, I also noticed a hydraulic fluid leak that seems to be coming from somewhere under the diesel tank that's dripping on the gear box right behind the starter (yannmar 18hp motor). This morning I ran it and started out fine, but quickly lost power again. First tractor so need help figuring this one out.
   / Tc18 loosing power hst and hydraulics #2
Sounds like you are losing fluid. I'd guess, from the location you mention, it could be in a power steering hose, but it's a pure guess. Do you have a loader? Could be a pinched or shot hose or line on the loader also. If you lose a significant amount of fluid, you won't move at all.
If not from hydro fluid loss, it could be a clogged fuel filter or water in your fuel.
   / Tc18 loosing power hst and hydraulics #3
Like OldFart said, sounds like you are low on fluid. There are connections up under there for the power steering hoses but there is also a connection that is just a hose clamp. I will lose hydraulic fluid through that. Not exactly sure what it is since obviously just being a hose clamp, it isn't high pressure. This is on the left side.
And in the FWIW department, your TC18 doesn't have a Yanmar engine, it is Shibaura.
The original owner custom ordered it with a yannmar. Buys one new every three years, and always orders the yannmar on them from the factory. Retired sales rep.
Killbros 385 Gravity Wagon (NICE) (A50774)
Killbros 385...
2015 CIMC 40FT CONTAINER CHASSIS (A52141)
2015 CIMC 40FT...
(4) Radial ST 225/75 R15 Tires (A50121)
(4) Radial ST...
Bad Boy 747cc Outlaw (A50121)
Bad Boy 747cc...
2012 Ford F-150 Crew Cab Pickup Truck (A50323)
2012 Ford F-150...
PENDING SELLER CONFIRMATIONS (A52577)
PENDING SELLER...
