TC 45D Hydraulics
   / TC 45D Hydraulics #1
vaalcom
I have a TC 45D with an attached 509 Bradco backhoe that was plumed by the dealer when purchased new. The spool seals on the Bradco have consistently leaked after limited use and have been replaced four times. Hydraulic pressure has been checked by a dealer several times and they say and is in specs. One hose to the 509 is attached to a removed plug on the joy stick spool just to the right of the tractors seat. The second hose is routed to the 509 from the # 2 port on the diverter block with the diverter placed in the 11:00 position. Could this set up be incorrect?? Would the backhoe be able to safely operate off an installed rear remote? Any help or suggestions would be appreciated
Thanks
vaalcom
   / TC 45D Hydraulics #2
Our Woods BH is run from one of the rear remotes and works just fine
CAT D8 (A58214)
CAT D8 (A58214)
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
(INOPERABLE) GEHL 8K TELEHANDLER (A58214)
(INOPERABLE) GEHL...
GMC 2500HD 4wd Service Truck (A56435)
GMC 2500HD 4wd...
NEW Fork Extensions (A59000)
NEW Fork...
2019 GALYEAN 150BBL STEEL (A58214)
2019 GALYEAN...
