Tc 45 da not starting
   / Tc 45 da not starting #1
owens123
odessa, fl
new holland tc45da
I have a 2007 tc45 da. It was running fine and then the engine stopped. The number 2 fuse was blown. I replaced the fuse and it started and ran for 10 seconds and cut off again. The fuse was blown again and it was 15 amp. I replaced fuel shut off relay number 2 and put a 20 amp fuse in the number 2 spot. It ran for 1 minute and then shut off again. This time it did not blow the fuse but will not start. It does turn over. For about a year the glow plug light on the instrument panel will stay on for about 10 minutes after starting and make a clicking noise then will go off. I would appreciate any help and advise as to what might be wrong. The tractor has 900 hours on it.
   / Tc 45 da not starting #2
Perhaps wiring short(s) or the shut off valve is bad.
What amazes me is why people think replacing a blown fuse with a bigger fuse will fix anything. Fuses are used to protect parts and/or wiring. :thumbdown:
JOHN DEERE 6155M (A53084)
JOHN DEERE 6155M...
2010 PETERBILT 387 TANDEM AXLE SLEEPER TRUCK (A52576)
2010 PETERBILT 387...
DeeZee Crossover Aluminum Truck Tool Box - Secure Weather-Resistant Storage for Pickup Beds (A52748)
DeeZee Crossover...
2017 Kubota KX080-4 Mini Excavator (A51573)
2017 Kubota...
2013 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A52748)
2013 Doyle Dry...
2016 TROXELL 130BBL VAC TRAILER (A52472)
2016 TROXELL...
