Tc 40d
   / Tc 40d #1
hoot1293
Is there a way to clean out the gunk in fuel tank without taking it off on a nh tc40d.
   / Tc 40d #2
Gas vapor is very flammable and could cause an explosion in case of any spark. Diesel is quite different and not as flammable. what I have done in the past was to take a long piece (30" long or a bit longer) 1/4" all thread and welded on a brass circular metal brush (from HF). You can dump most of the fuel in a bucket from the stop valve at the bottom of the tank. I mounted the rod to a drill and slowly brushed off the bottom and side of the tank. I did have the tank out but i don't think it is necessary, i then sloshed the diesel around and dumped the fuel in to a cup and it had some sediment and stuff in it. I actually filtered that fuel and put it back in the tank. Did it a few times, filled the tank and used the tractor for a few hrs and then changed the paper filter media in the bowl assembly.
Jc,
Deere 350G LC (A53317)
23013 (A55787)
23013 (A55787)
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
ELECTRIC GOLF CART (A58214)
ELECTRIC GOLF CART...
skeleton / rock bucket (A56857)
skeleton / rock...
backhoe attachment for full size skid steer (A56857)
backhoe attachment...
