Tc 40d
   / Tc 40d #1
hoot1293
Is there a way to clean out the gunk in fuel tank without taking it off on a nh tc40d.
   / Tc 40d #2
Gas vapor is very flammable and could cause an explosion in case of any spark. Diesel is quite different and not as flammable. what I have done in the past was to take a long piece (30" long or a bit longer) 1/4" all thread and welded on a brass circular metal brush (from HF). You can dump most of the fuel in a bucket from the stop valve at the bottom of the tank. I mounted the rod to a drill and slowly brushed off the bottom and side of the tank. I did have the tank out but i don't think it is necessary, i then sloshed the diesel around and dumped the fuel in to a cup and it had some sediment and stuff in it. I actually filtered that fuel and put it back in the tank. Did it a few times, filled the tank and used the tractor for a few hrs and then changed the paper filter media in the bowl assembly.
Jc,
1999 WABASH 48X102 FLATBED TRAILER (A52472)
1999 WABASH 48X102...
2011 GALYEAN 130BBL VAC TRAILER (A52472)
2011 GALYEAN...
2012 KENWORTH T600 SERIES (A52472)
2012 KENWORTH T600...
Case Maxxum 140 (A50120)
Case Maxxum 140...
2014 MAGNUM PRODUCTS LIGHT TOWER (A52472)
2014 MAGNUM...
