Tc 40d 3rd function
   / Tc 40d 3rd function #1
Scottstc
Wisconsin
New Holland TC40d
I bought my tc 8 months ago and really like it lately I have been considering a grapple. I use the tractor a lot for woods clean up. I致e been looking at 3rd function kits and they come with a new joystick with the grapple switch but I would lose the the hi low switches for my hst. Has anyone found a solution that you have both switches on the joy stick? Thanks
   / Tc 40d 3rd function #2
It not my idea (& I unfortunately don't remember who to give credit to) but I'm currently doing something very similar to this for the diverter valve on our TC40D... for use with a grapple
   / Tc 40d 3rd function #4
Sorry... not sure why they loaded like that... They do open for me... Ok I'll try this:
  • TC40D Joystick with extra button.pdf
   / Tc 40d 3rd function #5
My electromagnetic third function momentary contact switch is simply added to the existing joy stick so I simply slide my hand down on the stick and press the switch button to divert the flow to the grapple.
Took a little getting used to but works great. I do like the tidy ness of the switch enclosed in the existing handle however.
B. John
I really like the one posted first, did you just swap the switch that came in the kit for that one?
B John do you have a picture of your setup? It would help give me ideas.
   / Tc 40d 3rd function #8
My switch is a little different than the one I posted (that is where I got the idea)... I'm in the process of finishing mine up...
I went a little further than just swapping out the switch because the switch was not rated for the load of the diverter valve; I wired the switch to trigger a relay which the powers the diverter valve... still very straight forward. I had a harder time figuring out where I wanted to mount the valve...
What third function kit did you use? Picture of your switch would be great.
2005 Ford F-650 2,000 Gallon Water Truck (A53422)
2005 Ford F-650...
378813 (A51573)
378813 (A51573)
Selco V5-HD Vertical Hydraulic Baler (A55851)
Selco V5-HD...
2014 Mack CXU613 T/A Wet Kit Day Cab Truck Tractor (A55852)
2014 Mack CXU613...
Duetz Power Unit (A50120)
Duetz Power Unit...
2017 CATERPILLAR M316F MOBILE EXCAVATOR (A52707)
2017 CATERPILLAR...
